Sony KDL-32NL140: Powers On w/ Backlights, Black Screen - Bad TCON?
  • JDC
    • May 2015
    • 273
    (originally posted in power supply forum, reposted here)
    Got a Sony KDL-32NL140 that turns on to a black screen w/ backlights. I've pulled the back cover and confirmed that they are on. No sound to be heard.
    Attached are the top and bottom pictures of the TCON from ShopJimmy (not enough light right now to take decent photos of mine). Readings are as follows:
    F1 fuse:
    00.2 ohm while unplugged
    OL diode mode
    Using chassis ground as neg, both ends measure 11.97v. Shouldn't this be 12?
    On the bottom on the TCON are measure points. They are as follows:
    GND
    INSDA_1 3.32
    INSCL_1 3.32
    FWP_1 3.33
    VCC_1 3.33
    There are two tabs connecting to the LCD.
    Removing the left one shows a screen of gray on the left, white on the right. At first, it almost looks like denim jeans. After a minute,
    both sides become smooth with the gray side almost on par with the white side.
    Removing the right one shows a 2 inch white vertical bar on the left side, followed by gray until the middle,
    then another 2 inch white vertical bar, ending with gray til the end of the screen. No "denim" effect is shown.
    Ordering a new TCON is around 20 bucks. I'd like to rule out a bad panel first.
    Questions:
    What else can I test to rule on the TCON?
    What can I do to test the panel, especially in checking for good tab bonding?
    (Originally Posted by budm)
    Look for VGL, VGH, AVDD, VGMA with and without cables between the LCD and the T-CON connected.
    With cables connected:
    VGL -6.32
    VGH 26.80
    AVDD 15.73
    VGMA 15.29
    Without:
    VGL -6.34
    VGH 26.80
    AVDD 15.75
    VGMA 15.28
    Pretty much the same both ways.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sony KDL-32NL140: Powers On w/ Backlights, Black Screen - Bad TCON?
    Two threads ? Also got image of the grey area on the screen ?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Can you plug a DVD player or something similar into it via a Scart lead. I find very often that switching the DVD off then ON, the TV defaults to that input and so you can hear if there is sound.
      • JDC
        • May 2015
        • 273
        Unless an admin moved my original post from the Power Supply forum to here, there shouldn't be.
        I'll get the pic you requested here in a bit.
          Do you have oscilloscope to check the LVDS signals feeding the T-CON? So far it looks like the T-CON has good dcv.
          • JDC
            • May 2015
            • 273
            I don't but the more I get into TVs, the more it seems I'm going to need one. Recommend one?
            • JDC
              • May 2015
              • 273
              Please see attached.
                At this point I would try that new T-CON board, if there were shorted circuits in the panel then I would expect the VGH, VGL to be really low.
                • JDC
                  • May 2015
                  • 273
                  I'll get one ordered ASAP. BTW, what are normal reading for VGH and VGL? Or does it differ significantly from model to model?
                    They (VGL, VGH) look about right:
                    https://www.badcaps.net/forum/showth...&highlight=VGH
                    https://www.badcaps.net/forum/showth...ight=vgl+level
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      at this point i would try that new t-con board, if there were shorted circuits in the panel then i would expect the vgh, vgl to be really low.
                      +1
                      • JDC
                        • May 2015
                        • 273
                        TCON arrived, installed, no change. I took the TV apart further and have access to the panel circuit boards if you'd like to for to test certain points.
                        • JDC
                          • May 2015
                          • 273
                          Still playing with it, so far it's failed the flashlight test, this link suggested wiggling the LVDS cable in an effort to get *some* response onto the screen, still nothing.
                          I'm guessing a bad panel but how do I know for sure? What can I do?
                          • JDC
                            • May 2015
                            • 273
                            Bump.
                            • JDC
                              • May 2015
                              • 273
                              One more bump for the road. Next I'm going to try heating up the tab bonds a bit and see if I can get anything. I'm stuck between a bad panel and maybe a main board.
                              I hate recycling stuff when I can't explain why it's broke.
                              • JDC
                                • May 2015
                                • 273
                                Took the main board off and noticed multiple areas of discoloration. This isn't normal, is it? The set is from 2008, so...
                                • Diah
                                  • Feb 2013
                                  • 6611
                                  at yor first post you wrote No picture and No sound to be heard.... then why you go to T-CON. Video Process at main boards. faults.
                                  • JDC
                                    • May 2015
                                    • 273
                                    Live and learn, my man. I don't have a problem with getting another main board but I am interested in if there is a way to test panels that aren't cracked. Is there a method?
                                    EDIT: Actually, I can clarify why I went with TCON: My last TV repair adventure didn't have a picture or sound either. Turns out it was stuck on an AUX input; I never thought to hit the INPUT a few times to see if it would go a static channel. I did that with this one but to no avail.
                                    • Diah
                                      • Feb 2013
                                      • 6611
                                      there are no effective method for normal user like you an me to know if there are hidden panels that aren't cracked. unless eyes or power on or further oscilloscope signal measure according service manual given from manufacturing brands only.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Wait there, so even with a Tcon its the same failure ? If so I would say panel fault, possibly tab bonds. Also its normal for the Mb to get warm and discolor the Pcb like that.
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • rimwall
                                          Sony KD-65x7500D - double image - Tcon or Panel?
                                          by rimwall
                                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                          11-18-2025, 02:09 AM
                                        • thelankanguy
                                          Sony KD-55X9000F TCON Issue
                                          by thelankanguy
                                          The TV shows a black screen with no image.
                                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                          Later both ribbons were disconnected and TCON voltages were tested.
                                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                          There is also a short to ground in this circled inductor.
                                          Is this a TCON issue or something else ?...
                                          12-13-2024, 12:27 AM
                                        • bbrain
                                          Sony KD-55AG9 TCON?
                                          by bbrain
                                          I have this problem with my Sony 55' AG9.
                                          It flashes 4x.
                                          I have found the service manual, and seems it is the TCON.
                                          Before I buy a TCON can someone check the vid?
                                          Thanks in advance!...
                                          09-19-2024, 10:50 AM
