Samsung PN60E6000GF 60" Smart TV turns off, red flashing power light
  • Terryfictv
    • Mar 2011
    • 124
    Re: Samsung PN60E6000GF 60" Smart TV turns off, red flashing power light
    Sorry I meant soldered side! It's been a very long day !
    • kyij
      • Jul 2013
      • 45
      No worries, I was going to upload both sides but forgot too.
      • kyij
        • Jul 2013
        • 45
        I hooked the board back in out of curiosity and it's been on for 30+ minutes playing the movie off a USB. Weird that I am technically 2/2 with it working when the back plate is off. I just don't imagine anything could be shorting, plus I would assume a short would mean instant on/off, vs being on for 2 minutes.
        --Edit--
        Movie finished and it is still on. I may try to screw the back cover and leave it on the ground and see.
        • Terryfictv
          • Mar 2011
          • 124
          You are not contending with a short ! An intermittent open connection is more likely.
          Next step is to scrape clean the black off the ground connects on the solder side....
          The broken circle contacts where the mounting screws hold the PC board in place.
          I can clearly see in your pix ! All should be shiny...re-test after you do this step and
          if it does not fix, we will go to the next step.
          • Terryfictv
            • Mar 2011
            • 124
            Next = re-solder QS804,QS802,QM805 and DX852.
            Re-test.
            • kyij
              • Jul 2013
              • 45
              Re-test.
              I did both of your steps and have the TV playing the movie again; good so far. I would have to say QS804 definitely looked like it needed a touch up. Will update after I let the movie play through and put the back on and retest. Thanks
              • kyij
                • Jul 2013
                • 45
                So far, so good. Thanks everyone for the help. Hopefully I don't have to return to the forums for this tv!
                • martino
                  Not so "senior"
                  • Aug 2013
                  • 997
                  • canada
                  #48
                  Originally posted by martino
                  I do believe this to be plasma(correct?) so there is no T-con board.
                  Lot's of 60" and 64" plasma's from samsung suffer from bad solder joints on the power supply.Take a good look at all the components on the heatsinks. Sometimes it's really hard to see if they are cracked or not.
                  Read post #3 cough cough.
                  Proud owner of dozens of broken TV's and many,many,many boards.
                  Our website and passion:http://hollenhundshepherds.com/
                  • learnmore
                    Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                    by learnmore
                    Hello Community!
                    CASE DETAILS
                    Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                    13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                    Tried inserting firmware on USB and left it in for a few hours, but no change
                    03-03-2024, 09:49 AM
                  • Bloopeta
                    Samsung UE43KU6400U Flashing Red Standby Light
                    by Bloopeta
                    Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                    Power button does nothing
                    Have unplugged the mainboard, and backlights illuminate.
                    Have tried removing panel ribbon cables one at a time, and that makes no change.
                    With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                    Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                    09-11-2023, 02:34 AM
                  • Phil289
                    Samsung UE46EH5000 - Flashing red light but not turning on
                    by Phil289
                    Hi
                    I aquired a Samsung UE46EH5000 from a lady that said it was turning on and off so she just purchased a new one.
                    On plugging into the mains and turning on i get a solid red light.
                    On using the on/off button or remote i just get a flashing red light in a pattern of flash/flash gap flash/flash gap flash/flash etc.
                    Opened it up and disconnected the main board from the power board by removing the connecting ribbon cable with the hope of getting either a 'no backlight' or a 'working backlight' but got neither,i just got a blinking backlight that turned on and off randomly...
                    07-25-2022, 01:46 PM
                  • 7ony
                    Samsung plasma - flashing standby light
                    by 7ony
                    The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                    Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                    Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                    No visible...
                    08-31-2020, 05:18 PM
                  • esqmooo
                    HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                    by esqmooo
                    Hello everyone.
                    This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                    Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                    Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                    I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                    03-11-2025, 03:57 PM
