Sony KDL-65W850A Dead
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    #61
    Re: Sony KDL-65W850A Dead
    What is Digital_Standby?
      12 Ohms for the 12V DC coil is too low, if the relay coil is rated at 1W, then the DCR should be around 140~150 Ohms range, or higher if it is 1/2W relay.
        I did not trace that trace yet.
        BTW, that service manual is almost useless.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          #64
          That's obvious when you point it out. Just looked at the Fujitsu data sheet and it does say 11 ohms. Will dig deeper.
          Edit
          Coil resistance 270 ohms
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #66
              +1 And hard work going through it only to find that out.
              • kevinm34232
                • May 2012
                • 1884
                You won't have any AC voltage on bridge rectifier D6101 on the APS-356 until the relay operates. This is a 12V dc relay. Measue the coil resistance which had diode D6616 across the terminals with your meter set to ohms. It should be 12 ohms.
                Edit
                Updated coil resistance in later post
                Which coil are you referring to, I don't see a D6616?
                • kevinm34232
                  • May 2012
                  • 1884
                  Yes I agree it's given some info but nothing substantial...
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #69
                    Shown in attachment
                    • Diah
                      • Feb 2013
                      • 6437
                      as i wrote at Post No 2. its almost same as 65W955 and the SM useless, so i do suggest you to show us high resolution photo of the MB from both sides and please take out the shield cover out, as the DC _ DC converter at w955 are on the MB not at PWB
                      • kevinm34232
                        • May 2012
                        • 1884
                        Edit
                        263 ohms. I decided to order a replacement of this APS-356 and had no changes. 259 ohms on replacement board across the pins with D6616.
                        • kevinm34232
                          • May 2012
                          • 1884
                          Welp I got a replacement main board, and now TV responds to power button.
                          But, plugged in power, pressed power button, got a brief flash of backlights, then went out and front LED flashing green to amber over and over until AC unplugged.. Now no backlight flash at all just same green-amber flashing..
                          So this is progress, although disappointing.. Time to look at the SM again and see what this means.
                          EDIT:
                          [Quick look at SM and nothing describes this symptom, great...]
                          More info:
                          In standby, now get 3.3V STBY and REG12V. POWER_ON is also 3.3V. When power button is pressed, main board sends 3.3V to DIGITAL_STBY and BL_ON (relays click then go off in 1-2 secs).
                          There is a TCON_ON on the PS, that does not get a signal at all from main board during this time.
                          I then tried another LED power supply (APS-356), and got same results..
                          This is looking more and more like another bad LED light, or possibly the LED driver board.
                          • kevinm34232
                            • May 2012
                            • 1884
                            Found some info elsewhere which I had hoped to be helpful:
                            "I have found that on a good working set the BL_ERROR signal wire should read low/ 0V
                            so to simulate that I simply just grounded the BL_ERROR signal wire off of the connector cable on the G7 board or secondary power supply that powers the LD board
                            Unfortunately, this did not force backlights to stay on.
                            At this point I think it's either the LD board, or bad LEDs.
                            Anyone know how if I can do any tests on the LD board?
                            Part # is ST650LD-20S01
                            The 5 ICs are part # AN37011B
                            • kevinm34232
                              • May 2012
                              • 1884
                              So now (with main board disconnected), I jumped 3.3V to:
                              POWER_ON
                              BL_ON
                              DIGITAL-STBY_ON
                              This kicks on the 2nd power board (APS-356), but still no backlights.
                              The voltages on the 2 connectors on APS-356 are as follows:
                              14 pin connector (to/from LD board):
                              VLED_VCC = 60.75V
                              LD_ERR = 0.13V
                              GL_CTRL = 0.0V
                              REG12V = 12V
                              6 pin connector (to/from PS board APS-352):
                              BL_ERR = 6.17V
                              LD_ERR = 0.25V
                              DIGITAL_STB = 3.2V
                              BL_ON = 3V
                              REG_12V = 12V
                              I should mention that while checking voltages when everything was connected normally, occasionally I'd get backlights for a few seconds, and GL_CTRL would be around 1.1V.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                #75
                                You have BL_ON which is good but unfortunately BL_ERR is indicating faulty backlights.
                                Can you measure all 4 VLED_VCC and say what the voltage on all 4 connections are. They may go high when first switched on and then fall back.
                                You could also measure the primary and secondary resistance of each of the transformers and see if they differ significantly from one another.
                                You're almost there.
                                GL_CTRL......Unfortunatley I don't know what that stands for but does it say in the manual?
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  All 4 are the same.. What is normal voltage for these?
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #77
                                    Sometimes it says on the circuit board what the led voltage should be. Or it may be in the service manual. Normally when you have a faulty led the voltage on that line is different and is the give away that you have a led fault.
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      I should be getting some sort of backlights at this point if everything past here is good then, correct? What is the function of the LD board?
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        Any other tests I can do either from VLED_VCC, or from the wires going into the panel?
                                        • Diah
                                          • Feb 2013
                                          • 6437
                                          with replacement MB and every connected you have LED back light go on then off.. did you watched on the screen SONY Logo ? yes backlight Led shorted..
                                          disconnect the backlight socket from BL driver to LEDs and power on, did it stay on and indicator ON of Led at front of the TV. ? if yes can you see the picture with torch light... yes Led BL shorted or open..
                                          did it go in Standby ? if yes you need to make self diagnose mode via service menu because you have now replacement MB. read the SM. you will find how
                                          hope this help you
                                          • thstuff
                                            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                            by thstuff
                                            A) TV initially dead
                                            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                            12-26-2024, 09:10 PM
                                          • bohaboha
                                            SONY KDL-46R473A ALMOST DEAD NO STB
                                            by bohaboha
                                            Hello to everyone in this wonderful forum.
                                            I have this SONY LCD TV KDL_46R473a
                                            PSU GL5 APS350 :1-888-122- 12
                                            MAINBOARD FY13_EU IP-012C101-4010
                                            black screen ,no STB no life almost death.
                                            on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                                            Also 3,5,and 12v are on.
                                            nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                                            don't know what to do next all suggestions and advice are very welcome​...
                                            04-24-2025, 04:40 PM
                                          • Talyn
                                            Sony 55W905 dead
                                            by Talyn
                                            My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                                            I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                                            Any advice? Thanks!
                                            04-15-2024, 08:14 AM
                                          • mrsith
                                            Sony KDL-55W755C - Dead
                                            by mrsith
                                            Hello again lifesavers.
                                            I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
                                            I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I...
                                            11-28-2022, 12:42 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
