sony lcd vertical line
  • grendal10
    • Apr 2015
    • 25
    • United Kingdom
    i have got an sony 40" lcd with a vertical line, im guessing its not repairable as the line remains even with the tcon disconnected, ive got access to the top ribbons but pressing on them does not affect the line in any way. just wondering what might cause it?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: sony lcd vertical line
    Panel failure, not fixable sorry
    • CapLeaker
      Leaking Member
      • 8325
      That screen is toast.
      • grendal10
        • Apr 2015
        • 25
        • United Kingdom
        ok thanks, what causes the panel to fail like this? is it just age or heat?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          COF (chip on film) address driver for the screen. Some area of the chip break down causing rows on the Lcd to do weird things like what you have pictured. Its bonded to the Lcd and not replaceable so its scrap sorry
          • grendal10
            • Apr 2015
            • 25
            • United Kingdom
            its fine i had a feeling it would be scrap and was on a fact finding mission if its broken i like to know why! thanks for the information
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Hey why not just chop that tab off (address column for that tab will go black) and then fo the same for the end right hand tab and just have a 4:3 Tv ? If not maybe the Tv needs a meeting with your foot lol
              • grendal10
                • Apr 2015
                • 25
                • United Kingdom
                lol i think ill go with the meeting with foot idea
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  • otaku_nut
                    Vizio E701i-A3 fixed but now has red vertical line
                    by otaku_nut
                    Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                    08-19-2025, 06:11 PM
                  • TrueSword88
                    Kogan - KALED65XU9220STB - Blue Vertical Line
                    by TrueSword88
                    Hi all.
                    I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                    The line just happens to coincide with the end of COF and start of the next COF (attached).
                    The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                    Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                    Hoping to fix...
                    05-05-2023, 04:28 PM
                  • almarhum
                    To fix laptop screen vertical line by working on its EDP cable
                    by almarhum
                    Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                    As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                    05-07-2024, 02:12 PM
                  • blake.s
                    Sony KDL-70R550A has yellow vertical line in it
                    by blake.s
                    I have a sony kdl-70r550a that has a yellow vertical line in it on the right side of the screen. I am trying to determine if this is the panel tabs or if the t-con. T-con usual is not the issue if there are vertical or horizontal lines correct?
                    Attached are some pictures. You can see the right side has a discolored vertical line.
                    06-23-2020, 11:31 AM
                  • gpo23
                    Sony KDL-40V3000 - Vertical lines
                    by gpo23
                    i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                    With the new t-con the color are good but there are vertical lines on all the screen :
                    I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                    Is there a way to fix the vertical lines on the new t-con ?
                    Thank you for your help
                    gpo23...
                    10-04-2023, 09:11 AM
