Soniq E40W13A-AU Backlight Problem. Help a noob out
  • Kooda
    • Sep 2014
    • 15
    Hey guys! So yesterday my telly decided to pack it in. No signs of anything going wrong before hand. On startup it will play the startup sound and show the startup screen for a split second then fades to black. The image is then visible using the flashlight technique, so, definitely backlight I'm assuming? All caps etc. look to be in good enough condition and no discolouration anywhere. I've included a couple pics of the board arrangement etc. nt sure how much help they will be though. Please help, I'm gunna lose my mind without having a telly to come home to! TIA.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Soniq E40W13A-AU Backlight Problem. Help a noob out
    Suggest you read this, going to be fun to fix if your a beginner lol. My bet is Led backlight failure again:
    https://www.badcaps.net/forum/showth...light=Stacking
    • Kooda
      • Sep 2014
      • 15
      Haha sounds fun. Am I wrong in thinking that because the backlight still functions, albeit for less than a second, that it isn't a failure of the LED's themselves? Is there a way I could mabye run a jumper wire and see if the LED circuit is still intact and potentially functional?
      • Kooda
        • Sep 2014
        • 15
        Okay, so I measured 12v at the led pins when turned on, until the backlight flashes for that one second and it drops down to 0. Unplugged the led's and got the same result. Measured voltages a cable running from psu to main board. All seem to be okay barre one odd one out which was 4v (everything else was 5v or 12v)
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Your pictures are very fuzzy and hard to identify parts. 12V sounds far to low for an led supply which is often >100V mark. Is the LED voltage written on the power supply board?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Think theres a repair kit for the Psu for this for the Led drive area. Disconnect the Leds and retest the voltage.
            • Kooda
              • Sep 2014
              • 15
              I'll definitely take some hq shots tomorrow as to give you a better idea of the components. I did measure the voltage with the led's disconnected and it remained at 12v, well at least what I think is the led power wiring ( 2 pairs of wires running through the chassis, didn't light up on startup when unplugged).
              Also no, it doesn't appear to have marked voltages for the leds on the board, unless they're on the underside?
                BTW, please make sure it is straight shot pictures of the top and bottom side of the board and may good close up around the LED power supply/connector section too.
                • Kooda
                  • Sep 2014
                  • 15
                  Yep will do budm. Would have the capacitors discharged by now (10-12 hours or so)? If not is shorting the caps with a screwdriver generally frowned upon? Don't have any resistors etc on hand
                    Just measure the DCV right between the two legs of the cap, that is a sure way to find out if you still have lethal Voltage on the cap or not.
                    • Kooda
                      • Sep 2014
                      • 15
                      So I'm fine to measure such high voltages with a standard DMM?
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        If your dmm has a 1000vdc setting,yes.
                        Proud owner of dozens of broken TV's and many,many,many boards.
                        Our website and passion:http://hollenhundshepherds.com/
                        • Kooda
                          • Sep 2014
                          • 15
                          Okay, got some high res pics of the boards if anyone wants to see if anything stands out. Also, I'm assuming the led driver is built in to the power board, and the t-con board is the long board down the bottom? Would a faulty t-con cause backlight problems?
                          • Kooda
                            • Sep 2014
                            • 15
                            Okay so a tiny bit more progress so far. I've taken then panel apart to inspect the led's. Seems I was mistaken and only the bottom half of the backlight (two lengths/four individual strips) are lighting up momentarily on startup. Also, not sure if this means anything but, if i short the led terminals of each strip, it will light up different strips and different configurations. They are all able to be lit up besides one segment. Is it safe to say this is the culprit? Got a lil video if my explanation is a bit hard to understand. TIA
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Thats the issue then, have you watched my video ? If not it shows how to test them.
                              • Kooda
                                • Sep 2014
                                • 15
                                It is done! So god damn happy. After following your tut,I managed to track down the faulty led and fix it, although I simply had to bridge it with solder as I have no spare led's and such, but there is no loss of brightness at all and it's operating perfectly! Happy days
                                • triplefour
                                  by triplefour
                                  09-13-2023, 10:43 PM
                                • DanPoka
                                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                  by DanPoka
                                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                  02-15-2025, 05:05 AM
                                • Comp_Pro
                                  No Backlight Macbook A1990 820-01041
                                  by Comp_Pro
                                  Hello all,
                                  Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                  Tests performed:
                                  There is no backlight even with a good screen.
                                  Backlight IC is receiving the correct support voltages.
                                  Fuse F8400 ok
                                  Current sense resistor R8400 ok
                                  Backlight IC is receiving 3.3V on enable pin.
                                  Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                  Backlight IC receiving 5V from PP5V_G3S
                                  Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                  I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                  05-06-2024, 10:23 PM
                                • cheebster
                                  iPad Pro 12.9 5th Gen Backlight Issue
                                  by cheebster
                                  Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                  Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                  Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                  The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                  Anyone...
                                  05-20-2025, 09:17 AM
                                • canadaboy25
                                  LG Flatron 24EN33TA No Backlight When Cold
                                  by canadaboy25
                                  I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                  I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                  03-07-2023, 12:23 AM
