B+ issue
  • i4004
    • Oct 2006
    • 2029
    B+ issue
    this philips tv was dead. all voltages after the trafo were heavilly dampened. i unhook the b+, and sure enough stby lamp comes on.
    but the issue is this: i don't see short circuit on b+. it has about 45ohms. h.o.t. doesn't seem to be blown either(40ohms between pins), so i'm wondering what can cause such behaviour?
    ie b+ is choking the smps but no obvious s.c.
  • arneson
    • Sep 2005
    • 1267
    Re: B+ issue
    'This Philips TV' is not very specific.
    I have a 60' rear so I've een paying attention to them.
    They had a large screen capacitor problem one year ago in some models that resulted in a huge recall.
    It was an overheat of a backlight cap failure,
    but not for the one I have.
    Jim
    • i4004
      • Oct 2006
      • 2029
      Re: B+ issue
      it's 20" crt pal model made in poland.
      now you know it?
      hehe....
      it's not really model specific, what i'm really asking what the expected resistance of b+ against ground (-) when b+ rectifier diode is not connected...
      i don't wanna check h.o.t. if that's normal(offcourse, in the ballpark..doesn't need to be exact..)...
      hehm..perhaps it's short circuit somewhere on secondary side of flyback...uhm..don't you just like short circuit situations on unfamiliar model...
      that and intermittant errors...huh
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        Re: B+ issue
        45 ohms to ground may as well be 0.0 on the b+.
        what is it on that set?130v?
        pull the hot and check again.if no go lift the b+ pin of the fly.
        • i4004
          • Oct 2006
          • 2029
          Re: B+ issue
          i see 185V mark next to one diode in h.o. section...
          will check those 2 tomorrow.
          • i4004
            • Oct 2006
            • 2029
            Re: B+ issue
            removing hot does nothing. removing b+ from flyback(while hot was removed) restores normal voltages(b+ is 115V).
            this suggests flyback is shorted, right?
            presuming i can find replacement(need to check), how in the world do i desolder with such reinforced holes(see attached image)...
            • Krankshaft
              • Jan 2007
              • 2328
              Re: B+ issue
              A nice high wattage soldering iron and some desoldering braid always did the trick for me.
              Don't forget to loosen the mechanical connection from the flyback to the board out of all the flybacks I've removed most of them have had a screw or clip to prevent the flyback from flexing too much and cracking the joints or board. Sometimes the flyback is secured with a single screw to the rear cover when its installed.
              You should try doing a ring test on the flyback (if you have the Dick Smith tester).
              • i4004
                • Oct 2006
                • 2029
                Re: B+ issue
                don't have flyback tester, i can only check resistance against a good one, if seller agrees to do it prior to selling it to me(which they probably will).
                some methods are explained here
                http://www.repairfaq.org/sam/flytest.htm
                and here
                http://www.noahtec.com/testing-flyback-transformer.htm
                but none of this is real easy.
                i should find a schematic and try to see if there's excessive load on it's outputs, then remove and test it....somehow....uhm...
                • i4004
                  • Oct 2006
                  • 2029
                  Re: B+ issue
                  got a tip from another forum(otherwise this would be a bitch to diagnose..i would probably unhook everything from secondary and suspect trafo if that didn't help...):
                  shorted ceramic cap..removing it brings telly back to life.
                  b+ branch now looks like lytic to ohmmeter....
                  • ovrax
                    Philips 55PUS6804/12 turn on & off (probably backlight issue)
                    by ovrax
                    First of all, please excuse me as I'm quite new to this field.
                    I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                    I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                    The Ambilight works perfectly and stays on.
                    No sounds.
                    Thanks in advance.
                    08-25-2024, 04:33 AM
                  • charlesdutcher
                    No picture issue in Philips Chassis FTL2.1
                    by charlesdutcher
                    My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                    Is there someone having any symptom like this? How to fix it?
                    Thanks in advance!​
                    08-06-2024, 09:55 PM
                  • celiabrown
                    Issue with Plasma Philips 37inch chassis FTL2.1
                    by celiabrown
                    Hello guys,
                    My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                    Can someone has any symptom like this ?
                    Thanks​
                    05-09-2024, 10:56 PM
                  • DoOm86
                    philips 55pft5500/12 Backlight issue. What am I doing wrong?
                    by DoOm86
                    TV philips 55'' no backlight (image ok).
                    I tested the backlight with my led tester from the unplugged connector cable and it lights up. I had voltages at the motherboard connector, but anyway I order a new psu. Same problem, same voltages. Disassembled the TV and checked every strip with my led tester, they all light up, same voltage for every pair of strip (they go two by two).
                    What am I missing?
                    And something else I don't understand. I checked and I have 3v Leds, 10 per strips. Why every pair of strip (so 20 Led) take about 32v when powered up with my led tester πŸ€”
                    04-16-2024, 03:47 PM
                  • Nicktronic
                    Philips 75PFL5704/F7 A Video Issue
                    by Nicktronic
                    Hey everybody, got a strange one here.
                    The TV will display the Home Screen, Menus, Netflix Home Screen, YouTube home screen with preview tiles, etc, without issue. As soon as I try to play video (streaming or from any of the HDMI inputs), all I get is audio and and blank screen. It's like the video is not being processed. So I ordered a replacement main board. I can now play video from streaming sources but the video from HDMI sources is all green (kinda like photo negatives but all green) and the audio does not work. Is it possible the main board I ordered is also failing?? I can't...
                    10-31-2023, 05:43 AM
