I have a problem with sharp LC-60LE832U I order complete kit from Jimmy Shop .com power supply tcon board and motherboard/main .The question I have is the kit is for 70in tv and 60 in tv same board Sharp LC-70LE640U Complete TV .And the tv will not power up still giving me errors code of power and main bad .Can anyone explain the different if I am replacing the whole inside of tv.The main board on original is KF733 STICKER FM01S 2011 i UNDERSTAND FOR SIZE SCREEN BUT IT SHOUD POWER UP ? JIMMY SHOP CLAIMS NO .FIRMWARE MAYBE DIFFERENT BUT IT WOULD STILL POWER
Sharp LC-60LE832U
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
does... -
by gavenbHi folks!
I have a LC-80LE661U that had some interesting issues.
Initially, it would come on and show the sharp logo and would show normal static before shutting off.
I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it... -
by Superbee_dadHello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...01-24-2025, 11:51 PM - Loading...
