Samsung UE50f5000AW, backlight ok, no image no osd
  • yoritomo
    • Sep 2012
    • 147
    • Belgium
    Hello all
    This TV is lighting on the the backlight, but the screen still be black, no OSD or images appears, I checked the power supply , all voltages are OK.
    T-con model is AUO T500HVN05.0
    I guess the problem is coming from the T-con, any one can inform me how to diagnose it with the test points on it ?
    I can fix and check gamma problems already but this one is different,and information about t-con are always painful to find. I made a tour already of the smd fuses and diodes, but no results, surely a chip.
    Some test points should display on oscilloscope the digital video signal .
    Thank you for your help
  • yoritomo
    • Sep 2012
    • 147
    • Belgium
    Re: Samsung UE50f5000AW, backlight ok, no image no osd
    I have some new informations , i made a test disconnecting the ribbons on the t-con on pannel side, surprisingly i got a perfect half image disconnecting right one. doing reverse give a blank screen.
    i noticed something strange on that side on the corner, i didn't mind yet until now cause i found no relations, but the lower left corner has a damage, a small cloud of dead pixels always on, and a kind of small burn on the plastic.
    Then i checked the the rule circuit soldered to pannel, no trace of liquids, burns or any, capacitors and fuses looks good.
    I start to feel like the panel itself is dead.
      Are you getting 12VDC between the chassis GND and each end of the SMD fuse on the T-CON board?
      • yoritomo
        • Sep 2012
        • 147
        • Belgium
        It depends which fuse exactly because i have only one really close do the lvds connector, this one is 12.76V, the other , I could find another one close to a small AUO chip which has the same value. no change if I disconnect the panel ribbon.
          So you do have Voltage feeding the board.
          Good clear pictures of the T-CON board will help so we can see what we are dealing with.
          Also try having ribbon cable between the T-CON and the panel connected one at a time to see what happen.
          • yoritomo
            • Sep 2012
            • 147
            • Belgium
            This is a clear picture i could find on the net, better than mine .
            As i said already above i already unplugged alternatively the ribbons and could get an correct half image on right side.
              Sorry I missed post 2 about the ribbon cable, at this point the problem is in the LCD panel. It can be due to shorted Gate/Source drive ICs on the flexible PCB between the LCD glass panel and the tab bonding board, or shorted parts such as MLCC on the tab bonding board.
              • yoritomo
                • Sep 2012
                • 147
                • Belgium
                I reversed already both ribbons to check them but no luck, on the PCB pasted to the panel I see a small 8 pins IC, that may be the bad one, but I don't know how to test it, it is the only component I still doubt there.
                  There should be lots of light tan color rectangular caps (MLCC) that usually shorted out of have high leakage resistance,
                  • victor_cj
                    • May 2015
                    • 90
                    • Romania
                    You need to indentify and isolate with a litlle piece of duct tape only de VGH signal from the ribbon with problem.
                    The art of fighting without fighting
                    • yoritomo
                      • Sep 2012
                      • 147
                      • Belgium
                      On this model needs to disassemble all the shield, one surely burnt inside, that is the reason the plastic melted, thank you for your help . Now I understand what happens on it.
                      • wolf1976
                        samsung ue40d6100 has no backlight no sound and image
                        by wolf1976
                        hi to all
                        on the above model of samsung i have the faults i have told already on the title
                        iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                        any idea from someone what can i measure so i can find the problem ?
                        the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                        11-17-2024, 01:02 PM
                      • mi16rs
                        SAMSUNG UE32M4005AW BACKLIGHT OK BUT NO IMAGE
                        by mi16rs
                        Hi i have a samsung UE32M4005AW that have backlight but no image , i have changed the main board but still the same problem , so i guess it as a fault on the panel board , could some one help me on this ? thanks...
                        02-08-2024, 03:19 AM
                        09-07-2024, 05:50 AM
                      • C152Heavy
                        by C152Heavy
                        Summary for TL-DR readers:
                        • VCC pin (18) of PFC...
                        01-11-2023, 02:53 PM
                      • shelby5041
                        Samsung LCD TV no picture backlight on no 12v at tcon
                        by shelby5041
                        hi
                        i have a samsung lcd tv
                        it powers on with sound and backlight but no picture
                        all voltages from PS are good 12v 3.3v and 5v
                        whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                        i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                        no 12v at the tcon fuse
                        i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                        the odds of having 2...
                        10-08-2021, 08:21 AM
