Samsung main board part # interchangeability?
  • jm4designs
    • May 2016
    I have narrowed down the problem with my Samsung TV LN46B610A5FXZA to the main board, which is part # BN94-03141G. Only problem is, no one has it, not even eBay. There are an abundance of part # BN94-02621E, which uses the same base board # of BN41-01149b. A few sites list it as a substitute part, but a few eBay sellers have said that it won't work. Does anyone here know for sure? The boards visually look the same. Thanks in advance!
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Re: Samsung main board part # interchangeability?
    If you go to this page http://www.tvserviceparts.com/BN94-03141G.html
    It list boards that are factory recommended replacements.
    They are all pricey but maybe you can find one of them cheaper on eBay with a return policy.
    Also pts electronics repairs your board and they also list 2 equivilant boards.
    http://www.ptselectronicsinc.com/bn94-03141g/
    • Asraf Atb
      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
      by Asraf Atb
      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
      01-27-2025, 05:02 PM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • Lee M.
      Samsung UN75RU8000FXZA bad main board?
      by Lee M.
      When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
      11-08-2023, 07:46 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
