LG 50PK550 Plasma immediate shut down - SOLVED
  • gelectr
    • May 2014
    • 7
    Just posting so this may help others out:
    Had the above TV come in for the typical "click-click", and no picture or sound. Didn't find any problem with the usual 10R5W resistors, the standby regulator, or anything else. Eventually found T901 had broken solder on its pins. Resoldered it and the identical transformer next to it, and the TV works great now.
    Hope that helps someone!
  • bffargo
    2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
    by bffargo
    LG 60PB66550 NOV 2014
    PSU: EAY63168603
    PCB: EAX65359531 2013.11.01 Rev:1.0
    Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
    Symptom:
    While watching, just went black and started clicking relay every few seconds.
    Initial diagnosis:
    Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
    Deeper diagnosis:
    Pulling pins #1/#2 (Blue/Grey) from the connector housing...
    09-09-2022, 07:34 PM
  • cloo
    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
    by cloo
    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
    After doing a factory reset this problem was gone and the picture was back to...
    01-06-2025, 06:02 AM
  • ArMaaN376
    Samsung PS51E550 Plasma TV
    by ArMaaN376
    I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
    Opened TV cover & observed foll
    a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
    b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
    c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
    How to confirm Y -Buffer board...
    06-19-2024, 04:05 AM
  • mosfetratus
    macbook A2918, orange light off when shut off
    by mosfetratus
    When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
    Works with battery and charges, but when i shut off i get this problem.
    It had liquid spill. Board has no corrosion, keyboard is working, power button...
    05-31-2024, 03:34 AM
  • jm1234
    Panasonic plasma TX-P42ST50 - 6 blinks
    by jm1234
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults...
    05-22-2024, 06:59 AM
