LG RT42PZ45V standby ok no start
  • maxvalutech
    • 804
    • australia
    Re: LG RT42PZ45V standby ok no start
    Seems I was a bit previous with this one. My friend put it back together after I got picture but that was only menus etc and no signal going around the screen. But when reconnected to input sources the screen shows what I think are electrical interference thin black stripes at about 30 degree angle to horizontal from right to left all down the screen and over the picture. Have checked and reset Va and Vs. Can hear slight buzzing near power inlet when signal being received from any source inc DVD but no buzz otherwise. Any thoughts??
    • vinceroger69
      • Mar 2012
      • 6714
      can you upload a picture of what your seeing on the screen thanks
      • maxvalutech
        • 804
        • australia
        Will try upload via android on laptop......
        • maxvalutech
          • 804
          • australia
          Ahhh some success at last - very much like this pic with just more upward angle across the screen. The power board is made by another supplier to LG and no schematic but it is just overflowing with components. Three very big caps are 450v rating and other two which supply Vs Va are 250V and they all look OK. On the main board the set voltages are marked and adjacent are red lights which seem to indicate all ok too as check measured. Board also has about 5 green lights of which 3 remain on and two flash about each second.
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
          • valvashon
            Samsung UN65KU6290F PS board blows fuses
            by valvashon
            Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
            Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged...
            11-27-2023, 01:09 PM
