Lg led led no picture now
  • Mrntd
    • Apr 2016
    • 5
    • Usa
    The tv is a lg 39ln5700. The screen did have an image with the flash light test. At first we thought it was the power board. We replaced it with no difference.
    After reading more here I found a way to test the LEDs to see if that was it. Yep.
    Got the 4 strip pack and replaced the 2 bad strips. Before reassembling check to see if it worked. Yep we have light. Reassembled the tv, turned it on and a bunch of vertical lines. Brighter strip in the middle.
    Check the ribbon cables and the ends were damaged. Got replacements for those. No difference. Read some more, may be a bad t-con board. Got one of those. Now we have a black screen no image with flash light test.
    So now what? It's frustrating that it had an image before we took it apart and now it doesn't. I'm looking for some help.
  • comptek
    • Aug 2013
    • 606
    • uk
    Re: Lg led led no picture now
    any pictures of the fault ?
    • Electronic Handyman
      • Apr 2016
      • 58
      It's possible that you've some kind of bad connection double check all the plug in connectors connections, Be sure to check the soldering connections on those connections and the rest of the boards.You may even have a faulty PSU I'd try the old one again.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        You may have damaged the LCD panel tabs.
        It may be worthwhile taking a close look at the tabs that are fixed to the panel to see that they are not damaged.
        I have ripped one off when removing/re-installing a panel but thankfully only once and lesson learnt.
        • Mrntd
          • Apr 2016
          • 5
          • Usa
          It would just be a picture of a black screen.
          Both PS do the same thing.
          Checked the tabs (which are the thin ribbons coming out of the screen, right?) None are torn or or loose from the boards.
          Checked all the cables.
          Tried the disconnect one ribbon cable from the t-con to see if I got a half screen difference. No change.
          Even though the screen shows no damage could it have flexed too much while we replaced the LED?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            You are getting backlight right ?
            • Mrntd
              • Apr 2016
              • 5
              • Usa
              Yep. Back light is working fine.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                Can you post some sharp images of the circuit boards.
                • budwich
                  • Jul 2015
                  • 3097
                  When you say "cable ends damaged"... what does this mean... pictures? might provide some clues as to what you are battling... poor connection OR "shorted positioning"?
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    Tcon. How were you connecting the flat cables. There are clips which have to be lifted upwards, then attach cable, next clip back down again to lock them in place. Or are you pushing the cables back into the connectors?
                    • Mrntd
                      • Apr 2016
                      • 5
                      • Usa
                      I did push it in the first time. That is what damaged the flat cables. The contacts pealed back. The second set of flat cables I put in right flipping up the latch sliding it in and closing it.
                      • budwich
                        • Jul 2015
                        • 3097
                        hmmmm sounds like you need to "re-examine" your "work". IF you were trying to install those cables in the manner you just described, then it is quite likely that you might not understand how the cables are meant to be aligned in the connectors. Their alignment has to be very precise... there are small tabs on each side that need to be followed. Hopefully you haven't damaged the connector receiver portion.
                        • edugimeno
                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                          by edugimeno
                          Hi There!
                          I'm trying to help my friend who owns a restaurant be just bought.
                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                          09-05-2024, 09:34 AM
                        • lmcancu
                          LED Strip test points and testing?
                          by lmcancu
                          Hi is there a guide in this forum on how to test the LED backlight TV strips? I purchased an LED tester on amazon, but I am a bit confused on the test points and how to test the individual LEDs? I took apart a RCA 43" TV Rlded4331b. Please see attached pictures. I understand that all the LEDs are in series, but on these strips I don't see any individual test points for each LED? Any tips or guides?
                          Thanks in advance...
                          03-20-2023, 07:52 AM
                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 02:20 PM
                        • JJAAMM
                          by JJAAMM
                          Problem
                          07-06-2023, 06:01 AM
                        • Rauni
                          Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                          by Rauni
                          Hello, this is my first post on this forum, and my first attempted to repair a TV.
                          My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                          Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                          Read also that we should test what happens if we...
                          10-01-2023, 12:06 AM
