Hitachi P50H401A capacitor question.
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    I picked this tv up today for free. It works but I could see the back full of dust.
    I took the back off to blow it out and just look over the caps.
    They all look fine except I'm not sure about 2 huge ones on the psu.
    They are 100v 3300uf.
  • Electronic Handyman
    • Apr 2016
    • 58
    Re: Hitachi P50H401A capacitor question.
    They look like they could be starting to bulge.Since their close by the heatsinks and a very common value cap known to fail I'd forsure change them.In fact when I flip your pic upright I can see that those two caps the metal at the top on of them doesn't look flush they looked bulged.I'd also suggest that you change any other caps on the board especially the ones close by the heat sources like the heatsinks etc.What I do is if you've a 3300uf 100v cap upgrade the voltage to the next highest voltage cap that you can find.Make sure their high quality Low ESR caps. Sites like mouser.com, http://www.digikey.com/product-searc...=160v%203300uf, badcaps also have caps for sale.I'd go over all the boards soldering connections especially by the hot spots of the board and solder them.Just make sure you get ones that will fit that board.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      I have been buying my caps from digikey. I looked on there, these have different leads than the ones I'm used to changing. They seem short and stubby.
      Are they soldered on the same?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Common issue on these, they also have a habit of blowing the buffer when these caps fail so change them asap. Also got a picture of the whole back side of the Tv so we can see the chassis ?
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          This is what I was looking at.
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            Those you linked are too big. The ones in there now are 30mm. The smallest of the ones you linked to are 35mm. Those 2 are almost touching as is. There isn't another 10mm between the two.
            • MORETTIGIAN
              Capacitor detached from PCB – RTX 2070 Super Founders Edition
              by MORETTIGIAN
              Title:
              Description:
              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
              I did not notice it detaching, so I am unsure of its original location on the PCB.
              Procedure performed:
              - Removed backplate
              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
              - Reapplied thermal compound
              - Reassembled card
              Observed behavior after reassembly:
              - GPU powers on and operates normally under...
              09-18-2025, 12:14 PM
            • Prolog
              RTX 3080 FE Identifying capacitor
              by Prolog
              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
              I hope these photos make it clear which component I am referring to:
              (yes, the soldering is a bit botched from removing the blown one, I know)
              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
              12-01-2024, 08:27 PM
            • chth96
              If I replace with inferior capacitor, Is it No harm to other IC components at all?
              by chth96
              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
              I know that these capacitor will not last as long as nichicon capacitor...
              12-22-2023, 04:34 AM
            • chth96
              How can I test non-polarized capacitor?
              by chth96
              I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
              I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
              And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
              I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
              06-02-2024, 07:31 PM
            • chth96
              Is it no harm to replace with capacitor without ripple current rating?
              by chth96
              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
              Rubycon YK DataSheet (b...
              04-19-2024, 05:19 AM
