Bush Bpdp42hd2 (Samsung S42AX-YB09) screen going off.
  • Loz2212
    • Jan 2016
    • 61
    • United Kingdom
    Hi guys,
    Said I'd have a look at this for my old man, the tv turns on and then after a few seconds goes off with what seems like clicking from the PSU board relays. I've measured the Va, Vsc and Vs which all seem ok UNTIL the screen shuts off and the relay clicks then they quickly decay to zero. Assuming I have a short somewhere but my plasma knowledge is nil.. I don't even know which boards are what. I tried pulling boards to see if I could eliminate the board but the PSU won't output any voltages without the boards attached (assume that's normal?).
    Read over the odd post about these sets on here and I've heard they're a bit of a ball ache. Any help would be greatly appreciated. Thanks.
  • Loz2212
    • Jan 2016
    • 61
    • United Kingdom
    Re: Bush Bpdp42hd2 (Samsung S42AX-YB09) screen going off.
    Photo of the back. Thanks
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Based on Samsung 42C450 this chassis suffers from X-SUS shorts and this can cause the Y-SUS to fail too. The IGBT's go short.
      They, (Makers) recommend changing all three if the X or Y is faulty (Inc Control-Board) during repairs.
      Worth pulling out buffers and with everything else still connected try see if it runs as indicated by LED on control-board short flashing and Vs voltage remaining at 200 odd...
      TELEFIX
      • Loz2212
        • Jan 2016
        • 61
        • United Kingdom
        Thanks for the reply Alastair. Any chance you can tell me which boards are what in the back? Thank you.
        • sordids999
          • May 2013
          • 2158
          Standing behind the TV ysus is to the left and joined to that is the y buffer board
          To the right top is the xsus board and finally the control board is in the middle of the tv
          • sordids999
            • May 2013
            • 2158
            Look on YouTube for how to test buffers
            • crt man
              • Mar 2013
              • 106
              • England
              Hi
              To test Y buffer put meter in ohm setting and put probes across
              the two large caps if the reading is low IE about 70 ohm's,
              or is out of mega ohms then the buffer is shorted,
              If the relays click more than once them the two RJH30E2
              on the X sus will be short also, that is the two on the
              outside of each end on the bank of FET,s
              Alan.
              • crt man
                • Mar 2013
                • 106
                • England
                If you do that on this set, then if the Fets
                on the X sus are not short they will be
                after the action.
                Alan
                • Loz2212
                  • Jan 2016
                  • 61
                  • United Kingdom
                  Fantastic!! Cheers guys. Will be tomorrow now but I will post updates. Thank you
                  • Loz2212
                    • Jan 2016
                    • 61
                    • United Kingdom
                    Had a quick look tonight at the y-buffer board. Test between both caps was about 5 ohms. I tested along all the pins for the IC's and found one pin on one of the middle IC's was shorted to ground. I'll check over the other components on the X and Y main boards as well. Anything specific to look out for? Thank you.
                    • crt man
                      • Mar 2013
                      • 106
                      • England
                      Just what I said in p7
                      Alan
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        If you use the search and put in "Bush Bpdp42hd2" there are several threads which may help you.
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          after the action.
                          Alan
                          Err--
                          Just pulling Buffers and running this chassis with everything else still connected--Will NOT kill the X-SUS IGBT's! Ive seen many of these, even owned one for a while...
                          --Dunno where you got That from.
                          TELEFIX
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Ali he gets it from some newer panny sets removing the Ybuffer can kill the Ymain and possibly the Xmain too I have read up.
                            • Alastair E
                              Chief Womble
                              • Mar 2013
                              • 1963
                              • U.K.
                              OK--Right--
                              But we are looking at ancient Sammy tech here....
                              TELEFIX
                              • Loz2212
                                • Jan 2016
                                • 61
                                • United Kingdom
                                Thanks guys. So the x-sus IGBT's need checking and a new y-buffer board?
                                • crt man
                                  • Mar 2013
                                  • 106
                                  • England
                                  Err--
                                  I done it as an experiment with a set I have, and that is what happened.
                                  Done seven of them.
                                  Alan.
                                  https://www.badcaps.net/forum/showth...ight=bpdp42hd2
                                  • Alastair E
                                    Chief Womble
                                    • Mar 2013
                                    • 1963
                                    • U.K.
                                    Hmm--Ive done 30 or 40 of the bloody things over the years...
                                    TELEFIX
                                    • crt man
                                      • Mar 2013
                                      • 106
                                      • England
                                      But you are a professional are you not.
                                      I just do this as an interest, it was the first plasma
                                      I had done, and done seven in about a six month period,
                                      the only other flat screen was an led with poorly
                                      seated ribbons.
                                      I found some strange things with this plasma,
                                      that did not check out with threads on other
                                      sets.
                                      As I said I done it as an experiment and I
                                      was not talking out of the top of my head
                                      Crt's is my thing.
                                      Alan.
                                      • Alastair E
                                        Chief Womble
                                        • Mar 2013
                                        • 1963
                                        • U.K.
                                        Aye--Flatties is my profession--CRT's a hobby Started out in the era of the G8 and Pye Hybrid!
                                        CVC2 with replacement CRT and TV62 with dodgy CRT heater, and TV125 in collection--Still hoping one day to find a G6 (G22K511/2) ....
                                        TELEFIX
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
