RCA RLDEDV3988 picture flashing
  • tech2014
    • Aug 2014
    • 807
    Hi guys. I have an LED tv with a strange problem that I have never encountered. When you turn on the tv, the screen comes up, then you get the no signal box appear and then the screen starts flashing, almost like a blinking LED. Would this be a bad LED strip or a power issue?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: RCA RLDEDV3988 picture flashing
    Is it the backlight ? If so start with checking the Led drive voltage see if its fluctuating. You should know where to start by now.
      May be the same as this: https://www.badcaps.net/forum/showth...ght=RCA+LED%2A
      Try disconnecting the DIM control line.
      • tech2014
        • Aug 2014
        • 807
        I took apart the TV and tested the LEDs. I put about 30V on the +/- connector of each strip. All of the LEDs work, which surprises me because every other RCA I have taken apart is always the LEDs. It is late so I am done for tonight. Tomorrow I am going to test each strip for about 15 minutes too see if maybe some of them will blink after being on for a while.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8327
          Turn down the backlight maybe to 50%?
          • tech2014
            • Aug 2014
            • 807
            It was already at 50%.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8327
              That sux.
              • maricm
                Vizio m65-c1 picture flashing on and off on the screen
                by maricm
                HI all,
                hope someone point to the possible issue before I start buying replacement parts.
                Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                Backlight stays on all the time,
                Sound works fine.
                screen keeps changing form black to full picture in about 1sec intervals.
                Picture looks fine with no visible artifacts.
                I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                Disconnecting left and right ribbons on...
                11-25-2023, 06:32 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • arbitarytwist
                Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                by arbitarytwist
                Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                03-01-2025, 01:16 PM
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
