Sharp LC-46D62U vertical lines
  • tech2014
    • Aug 2014
    • 807
    Hi guys. I have a Sharp LCD tv with vertical lines. I suspect this is a TCON issue since I get lines through the menu when I press the menu button. Is this correct or could it be a main board or panel?
  • CapLeaker
    Leaking Member
    • 8327
    Re: Sharp LC-46D62U vertical lines
    first clean the LVDS connectors between main and Tcon board. Then the cables from Tcon to LCD. See if something changes.
    • tech2014
      • Aug 2014
      • 807
      I cleaned them and its still the same
      • CapLeaker
        Leaking Member
        • 8327
        Disconnect one side of the tcon, check the picture then the same on the other side.
        • Sevenqi
          • Jul 2011
          • 292
          This is the main board issues. Try to reflow the two chips on the main board. Search the threads on this forum.
          • tech2014
            • Aug 2014
            • 807
            Here you go capleaker. The top pic is the screen with the right side TCON cable removed from the panel, bottom is the left side removed.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Budm provided the following pdf which may be of some help. Since the pattern is uniform I think it looks like that shown in Fig 4
              • CapLeaker
                Leaking Member
                • 8327
                Did you try heating (hair dryer) or cooling (can of air upside down) the Tcon and the main board while watching the screen?
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • Falki
                  Colorful LCD Vertical Lines on Samsung ue55es8090
                  by Falki
                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                  A similar issue has been posted as well but also with no actual response ...
                  08-12-2025, 04:19 AM
                • visionbluedemon
                  Help. Sony kd-65x85dj vertical lines
                  by visionbluedemon
                  First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                  Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                  tried blocking LC lines too, but same results
                  is it lcd panel issue or tcon board issue?...
                  07-25-2025, 04:56 AM
                • gpo23
                  Sony KDL-40V3000 - Vertical lines
                  by gpo23
                  i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                  With the new t-con the color are good but there are vertical lines on all the screen :
                  I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                  Is there a way to fix the vertical lines on the new t-con ?
                  Thank you for your help
                  gpo23...
                  10-04-2023, 09:11 AM
                  LCD LED TV Service Menu Codes
                  ALL LCD LED TV SERVICE MENU CODES
                  Service Menu Code with Board Name
                  China Universal Board / Jumper Board Service Menu Code
                  Changhong Ruba Service Menu Code
                  Ecostar LED TV Service Menu Code
                  Orient LED TV Service Menu Code
                  Haier LED TV Service Menu Code
                  TCL LED TV Service Menu Code
                  Samsung LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  Videocon LED TV Service Menu Code
                  Supra LED TV Service Menu Code
                  Toshiba LED TV Service Menu Code
                  Symphony LED TV Service Menu Code
                  Veste/ LED TV Service Menu Code...
                  10-31-2024, 03:58 AM
