Bush LT26M1CA intermittent fault
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    The intermittent problem is that the TV will power on ok most of the time. Unfortunately sometimes it just powers on to a blank white/grey screen. Sound is present.
    It was worse until I pulled it apart and then put it back together. Sometimes it will run away fine all day. Then some mornings it powers on faulty. Re-power and it's ok.
    Could this be bad caps? PSU looks good, no overheating. Caps look good also.
    Any ideas, pleases help.
    Hab.
  • sordids999
    • May 2013
    • 2152
    Re: Bush LT26M1CA intermittent fault
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Image of the fault please ? Sounds like tab bond issue to me.
      • habanerocat
        • Nov 2014
        • 96
        • Ireland
        I've uploaded a couple of photos below.
        TV has been ok today, so no image of the faulty screen.
        Generally it's just a blank white/grey screen. Sometimes some light shaded lines are visible. TV menus don't display. Sound come through ok.
        • habanerocat
          • Nov 2014
          • 96
          • Ireland
          Here is a sample of how it powers on sometimes.
          Any ideas, anybody?
            • 31028
            did you replace any caps?
            there is a poly in the psu and a rubycon on the main - very strange!
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              If you try flexing or tapping the top corners of the screen does the fault come and go ?
              • habanerocat
                • Nov 2014
                • 96
                • Ireland
                No, I haven't replaced any caps.
                • habanerocat
                  • Nov 2014
                  • 96
                  • Ireland
                  No, flexing or tapping doesn't seem to make it worse or better. It seems to be related more to powering on with or without the fault.
                  With that said I have once seen it go faulty while on. Also it came good once when I touched the ribbon cable between main and the screen (pictured).
                  • CapLeaker
                    Leaking Member
                    • 8161
                    What happens if you heat the TCon board up with a hair dryer, then turn the TV on?
                    • jdawg99
                      Bush DLED32287HDCNTDFVP - Is this a screen fault or a Tcon Issue
                      by jdawg99
                      Trying to fix a bush TV. The Tcon is integrated onto the main board by the looks of it but before I buy a replacement does this look like a screen fault? The lines at the bottom are concerning me. I have check for shorts on the caps etc and can't see anything obvious. Nothing is overly hot and I've tried heating different boards and pressing down on the flex but no change in picture.
                      Any advice welcome. Thanks in advance....
                      09-18-2022, 05:30 AM
                    • Rictech
                      Panasonic SA-MAX770PU SMPSU board fault....
                      by Rictech
                      Hello everyone. 😀
                      As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                      Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                      Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                      This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                      There are no devices that have exploded or otherwise show signs...
                      08-26-2024, 01:05 AM
                    • protocold
                      MacBook Pro 15" 2010 820-2850 intermittent charging
                      by protocold
                      I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
                      I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
                      when it is not intermittent:
                      PPVBAT_G3H_CHGR_R is 12.07v
                      when it is intermittent:
                      When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
                      when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
                      data line on the battery...
                      07-25-2025, 08:18 PM
                    • CDNBrewer
                      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                      by CDNBrewer
                      Hello Everyone,
                      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                      Symptoms:
                      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                      • I swapped the Left and Right surround
                      08-05-2025, 09:29 PM
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
