Samsung PS50B550T2R Bang
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Good afternoon, could somebody help with this arcing Tv. This is the second one with the same complaint -- a loud "doof" noise. The first one had arced violently (like a crt Tv with an arcing loptx) whilst taking voltages. I sent it in to the local agent, who returned it saying the Panel was faulty.
    This one one comes on with the standby led flashing red, the green led on the control board flashing. Vs is labeled as 209 volts, measures 203 to 205 (fluctuating). Va labeled 56 volts measures 55 volts. Vcc not lableled but fluctuating between 181 & 191 volts. Not sure where to measure Vsc & Ve.
    Photos 1 & 2 Top & bottom of Y Sustain board
    Photo 3 showing sticky liquid having leaked from heat pad? Is this a faulty heat pad, or has it just got too hot? Has this caused the fault
    Photo 4 showing arcing under U5000 ic.
    Photos 5 & 6 show conditions set has been operated in vents blocked & salt formation on back cover.
    Would it be worthwhile repairing considering the environ its going back to, and its age, and obviously price & availability of the Y & Z sustain boards.
    How rugged are plasma panels? Can a moist seaside environ cause premature failure of the plasma panel?
    Thanks.
    • 31077
    Re: Samsung PS50B550T2R Bang
    there is a LOT of cracked solder joints on that board,
    and you should brush the dust off before looking at it or taking foto's
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      U5000 doesn't look so good? Pin 7 is arcing to ground.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        I repaired one of these Ymains. Normally you will have some shorted transistors which is what blows U5000 you need to check the transistors for S/C.
        • Grunder
          • Jan 2016
          • 323
          • south africa
          The size of the discharge/ burn mark made me think that a lot more than the ic was poked, so any work (cleaning & dusting) would be futile? I thought ascertaining repairability before any work continued?
          • Grunder
            • Jan 2016
            • 323
            • south africa
            Maybe sometimes the damage looks a lot worse than it is, it was just that the identical set I had before crackled (like my testicals receded crackle) made me think that this particular panel had a history of taking out the board, and that any repair attempt would be futile.
            • Grunder
              • Jan 2016
              • 323
              • south africa
              Okay, will start cleaning up and checking other components, and if it looks not to bad will try source ic and attempt repair.
              In the mean time Samsung have quoted 1800ZAR for the Zsus & 2215ZAR for the Ysus. I have been told that in the event of pcb replacement to change both boards at a time, or the set will just return.
              This would make the repair price ridiculous. Just don't want to waste time repairing, only to have the the panel bang them to pieces again. Thanks responses.
                09-07-2024, 05:50 AM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
                Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 06:20 PM
