Protron PLTV-37C no display, stuck in standby
  • jasonbay13
    • Jul 2014
    • 185
    • usa
    A similar topic: https://www.badcaps.net/forum/showthread.php?t=22148
    a related youtube video: https://www.youtube.com/watch?v=Nit9pt2B-tY
    brief description: plug in the tv and the light comes on amber for a second then goes red and stays red. power button does nothing (can eventually get it to try turning on again, same results as plugging in). i can hear the speakers pop, tried looking with my flashlight for screen items, but saw nothing.
    what i've checked:
    • brief visual inspection without removing the boards.
    • Voltages as shown in images (of which if you want better quality, just ask where)(probably under the hv shields)
    • there is a little button on the logic board so i pressed it and it seems to override the power button, but it only does as much as plugging in tv does.
    Questions: do you think its even worth bothering with or just use it for scrap?
    in not, should i be looking at the inverter boards only? as i could see nothing on screen (lights off, flashlight to screen, plug in tv)
    finally got leads for my oscope and learned how to turn it on and get something on the screen
  • CapLeaker
    Leaking Member
    • 8250
    Re: Protron PLTV-37C no display, stuck in standby
    The pictures of the PSU aren't that great. We need high res, straight shot pictures. We also need to see whole connectors, not half of them covered.
    Take your DMM out and check what you get on all the pins (connector that goes from the PSU to main board) with the TV off and on. Post pin out name with voltages measured.
    • jasonbay13
      • Jul 2014
      • 185
      • usa
      More pictures! as for pin measurments... getting that now.
      edit: measurments on connectors at power board are:
      CN2: +16v,+16v,+16v = .4 off / 16.2 on (earth is 0)
      CN3:
      on/off = 0 off / 3.23 on
      earth, earth = (0)
      +5v, +5v = 5.06 off / 5.05 on
      CN4,CN5
      +24v (all) = 3v off / 24.2 on
      earth = (0)
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        You say that you could hear the speakers pop when you switch on so can you look very carefully and see if the backlights flash on very briefly or not.
        • jasonbay13
          • Jul 2014
          • 185
          • usa
          Nothing.
          seems i didnt mention i tried turning the tv on whilst room completely dark, with and without flashlight to screen and saw no slight lighting of said screen. also didnt see anything with the flashlight but it could be the logo is where i'm not looking.
          • CapLeaker
            Leaking Member
            • 8250
            Just for shits and giggles... on the main board there is a socketed flash IC. Make sure it is firmly in it's place. These things can wiggle themselves out after countless heating and cooling cycles an do weird things to the TV.
            Next thing we need to know if the main board is sending PSon and BLon to the PSU. Since there are tons of caps on that main board, it wouldn't hurt going over them with an ESR meter. Only because they look good, doesn't mean they actually are good.
            • jasonbay13
              • Jul 2014
              • 185
              • usa
              reseated that chip. no change going for the caps now. you said on the main board, but are there any in particular?
              • jasonbay13
                • Jul 2014
                • 185
                • usa
                in the middle of checking the caps i was looking at the inverter boards where the power comes in to them, on board M1 there is a white smd block that says K0AC 5A, i'm guessing is a fuse. there is one on each connection, this one reads 5megohm on one direction and open in the other, the others all read .01 ohm.
                • jasonbay13
                  • Jul 2014
                  • 185
                  • usa
                  alright, i killed it even more :P
                  put a 5A fuse in place of that white thing. while also measuring blon at the inverter (which i now just found) shortly after the blon signal came zd701 let out the magic smoke.
                  so based on this i do believe the inverter board is bad. now the question is, do i replace the M1 board and hope theres nothing else wrong, or just scrap it?
                  http://www.ebay.com/itm/Sceptre-Back...8AAMXQuTNTKwNv
                  • CapLeaker
                    Leaking Member
                    • 8250
                    So the main board is sending PSon and BLon. That's a plus. I am not sure, my eyes don't cooperate on my little screen, but it looks to me ZD901 that goes to a small 8 pin IC? Anyhow. For 25$ isn't much to invest, main board looks promising by having PSon and BLon, however you could verify video be measuring the LVDS with an oscilloscope and turn the menu on and off all the time.
                    If you junk it or not is up to you. After all the TV is 10 years old already.
                    • jasonbay13
                      • Jul 2014
                      • 185
                      • usa
                      Lvds?
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Originally posted by jasonbay13
                        Lvds?
                        The cable or flat ribbon which carries the video signals from the main board to the Tcon board.
                        • jasonbay13
                          • Jul 2014
                          • 185
                          • usa
                          alright. i did check it with my scope. couldnt get a clear trace though, but some of the pins did change pattern upon pressing the menu button. so you think theres a good chance replacing the M1 board will fix it?
                          also, just checked with the flashlight again, reason i couldnt find anything is i was looking in the wrong place. the no cable is written on a black screen in the center. even with my fairly bright flashlight up to the screen i could only make out not even an inch from the light a change in pixels. (as compared to another screen i saw it lit most of the screen up enough to see faintly).
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            So just to clarify you do have a picture on the screen but no backlights. Have I understood you correctly.
                            • jasonbay13
                              • Jul 2014
                              • 185
                              • usa
                              yes, there is image on the screen. no backlight whatsoever. (though it is odd, the tv indicator light stays red which i've never seen on a tv-only monitors when there is no input)
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                So when you put the 5A fuse in you killed the inverter board so at least you know that the main board had switched the inverter (backlights) on.
                                I suspect that is your only problem now and if you replace your inverter boards you should be up and running.
                                • jasonbay13
                                  • Jul 2014
                                  • 185
                                  • usa
                                  alrights. thanks a lot for going through this. i still havent decided if i'm gonna grab that inverter board or not. i'll update this if i do get the board. thanks again, both of you.
                                  • CapLeaker
                                    Leaking Member
                                    • 8250
                                    So you do see now a picture on the screen, just no back light? Well... then change that inverter board.
                                    • jasonbay13
                                      • Jul 2014
                                      • 185
                                      • usa
                                      i decided the tv is not worth me fixing and have disassembled it. i do have all the parts for it stashed so if anyone needs anything from it besides the main inverter board i've got it.
                                      • lepak06
                                        TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                        by lepak06
                                        Hello
                                        I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                        The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                        Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                        All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                        But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                        01-12-2023, 01:43 AM
                                      • toty79
                                        Hisense LTDN50K220WSEU stuck in standby
                                        by toty79
                                        Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                        As per Hisense tv title LTDN50K220WSEU stuck in standby
                                        PSU rsag.820.5687 HLL 4855WF
                                        Main rsag 7.820.5842
                                        I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                        05-01-2022, 04:39 PM
                                      • lego1234567
                                        LG 32LB1R - stuck in standby mode
                                        by lego1234567
                                        Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                        What could be the problem ? Thanks...
                                        01-21-2024, 03:39 AM
                                      • Stunt
                                        Hp Laptop Stuck on Hp protected by hp sure start screen
                                        by Stunt
                                        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                        screen that's it and stuck there. I left it until the following day and i still...
                                        09-02-2025, 01:51 PM
                                      • Rusenga
                                        Samsung UA39EH5003R Stuck on standby
                                        by Rusenga
                                        Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                        Connector CNM803:
                                        TV ON
                                        Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                        TV OFF
                                        Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                        09-18-2021, 11:51 AM
