LG 47LN5200_U: PWR, MAIN, and all LEDs replaced, no picture
  • CapLeaker
    Leaking Member
    • 8327
    Re: LG 47LN5200_U: PWR, MAIN, and all LEDs replaced, no picture
    At this point I'd really like to verify the LVDS on a oscilloscope, if there is any possibility for you to get the hands on one...
    BTW: did you already try do disconnect only one of the ribbon cables on the Tcon that go to the LCD screen, then vice versa... in order to see if there maybe half of the screen comes up?
    • JDC
      • May 2015
      • 273
      I did that and there was no change. As for an oscilloscope, I don't have access to one.
      For clarification, the LVDS is the cable that runs from the main board to the TCON, correct?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        #83
        Yes, that is the cable.
        • JDC
          • May 2015
          • 273
          Awesome, thanks.
          I know what an oscilloscope looks like but have never used one. For further reference, what would the oscilloscope tell me about the LVDS cable?
            Please check the DCV (when TV is turned ON) at those test points I have marked: Black probe on the chassis.
            VCC =
            VCC18 =
            VGH =
            VGL =
            VDD =
            VCORE =
            HVDD =
            • JDC
              • May 2015
              • 273
              Originally posted by budm
              please check the dcv (when tv is turned on) at those test points i have marked: Black probe on the chassis.
              Vcc =
              vcc18 =
              vgh =
              vgl =
              vdd =
              vcore =
              hvdd =
              vcc = .026
              vcc18 = .025
              vgh = .022
              vgl = .050
              vdd = .018
              vcore = .022
              hvdd = .024
                Originally posted by JDC
                vcc = .026
                vcc18 = .025
                vgh = .022
                vgl = .050
                vdd = .018
                vcore = .022
                hvdd = .024
                This is done with the TV powered ON? You have 12V feeding the T-CON fuse F1 but the switching power supplies are dead. Based on those Voltage readings you have made the T-CON board is dead at this point.
                BTW, I hope you did the test correctly.
                • JDC
                  • May 2015
                  • 273
                  I'm pretty sure I did the test correctly. I had to run my pos. probe over a file to 'sharpen" it a bit as I wasn't sure I was hitting those small areas correctly.
                  In any case, I've got a TCON on its way.
                  EDIT: Yes, the test was done with the TV on.
                    OK, I hope that will be it.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #90
                      If you can provide feedback after fitting the replacement Tcon would be good.
                      • JDC
                        • May 2015
                        • 273
                        Absolutely.
                        • Diah
                          • Feb 2013
                          • 6437
                          i hope you will remark this threat as SOLVED before its reach 100 post lol... this is manufacturing TV not repairing LG.. cheers up
                          • JDC
                            • May 2015
                            • 273
                            lol, can't argue with that.
                            • JDC
                              • May 2015
                              • 273
                              TCON arrived, no change to the TV. Man...
                              This leaves the LVDS cable and the panel I guess.
                                So you still have 12VDC at the F1 fuse of the NEW T-CON but no DCV on any of those test points?
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #96
                                  Something is not right!!!!!!!
                                  Do you flip up the tabs on the ribbon connectors to insert/remove the cables and then click them back down to lock the cables in place or are you pulling /pushing the flat cables into place???
                                  • JDC
                                    • May 2015
                                    • 273
                                    WAIT! Oh man! I spoke too soon!! Hold on...
                                    • JDC
                                      • May 2015
                                      • 273
                                      I'm seeing snow on the screen! Stand by....
                                      • JDC
                                        • May 2015
                                        • 273
                                        *whew*
                                        Well, what did you think happened? When I put the new TCON in, I mustve not inserted the 2 strips in all the way into the panel, so I immediately posted the result here.
                                        I went for broke and redid it all. Snow, glorious snow on the screen.
                                        I intend to update the 1st post with the solution plus what I've learned from this.
                                        Thank you all so much. I learned so much from this experience, mostly to take your time and use a magnifying glass.
                                        EDIT: I guess I can't edit the first post. budm, dick_barton, diah, capleaker, and anyone else I missed, thank you so much for help me save the TV from the dump. I'm very proud of this!
                                        • dick_barton
                                          • Aug 2015
                                          • 6643
                                          • Wales
                                          #100
                                          Well done. Now to show us a picture on the screen.
                                          • gavric
                                            Vizio M70-C3 Half picture is bad, main board on its last leg?
                                            by gavric
                                            Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                            When tv powers on vizio V logo shows nice on whole screen. picture 1
                                            When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                            When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                            When i click video to start playing picture goes black(like when you change...
                                            09-02-2021, 08:55 PM
                                          • EazyBone
                                            Samsung QN82Q70RA backlight mystery
                                            by EazyBone
                                            I picked this up and it had picture but no backlight. I was somewhat familiar with his TV as the LED driver fails a lot on this model. But when I tested the LED driver it had all the voltages necessary. I even had a spare one to try out just in case and that one did not solve the problem either.
                                            I tested all the LEDs before pulling the screen apart but ended up pulling the screen apart anyways to further test them. Every one of them tests at 90 volts with the tester. They all light up. I replaced a couple as seen in the picture because I had extra and I accidentally popped the cap...
                                            04-23-2025, 06:15 PM
                                          • signal.quest
                                            Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                            by signal.quest
                                            I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                            03-17-2024, 10:14 AM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
