LG 47LN5200_U: PWR, MAIN, and all LEDs replaced, no picture
  • JDC
    • May 2015
    • 273
    Re: LG 47LN5200_U: PWR, MAIN, and all LEDs replaced, no picture
    Those are only half of the pin outs. There are 18 of them in total. We need all of them plus the pin out name!
    However... there is no voltage going to the Tcon. no voltage there, no pic. Maybe disconnect the tcon and see if the voltage re appears on the connector.
    ON
    -.009
    12.13
    12.13
    -.01
    24.48
    -.011
    3.51
    3.51
    3.104
    OFF
    0
    .009
    .009
    0
    .006
    0
    3.55
    3.55
    0
    Attached is a diagram for the connection from the power board to the main board. It says:
    P201
    GND GND
    12V N.C.
    12V 12V
    GND GND
    24V 24V
    GND GND
    3.5V PD1M2
    3.5V PD1M1
    PWR-ON DRV-ON
    • JDC
      • May 2015
      • 273
      Originally posted by dick_barton
      Edit
      Please can you provide some sharp picture of your main board which would be of help.
      Is this better?
      • JDC
        • May 2015
        • 273
        Originally posted by Diah
        from yours T-CON photo it show to me the left ribbon cable not correct sitting at the panel socket., take them both out and check the Gold pins of them, then reset them correct, as they labeled with hand writing they seem had story.
        Reseated, nothing out of the ordinary I could see, still no change. Thanks anyways.
        • charis
          • Mar 2016
          • 61
          • greece
          If your backlight start and the panel stay black is T con problem.
          Usualy this symptoms happen to samsung tv but the sound works.
          Try to heat the main processor and see if you have picture untill he cools .
          Also check the regulators near processor specially the 5v and VCC.
          If nothing happen your tcon is faulty.
          To test Tcon jump 12v from SMPS to the Tcon fuse.Disconect the LVDS cables Jump VCC 3.3v to the LVDS(CN1) connector ground pin.Aply ac to power supply, patterns of White, Red, Blue, Green
          should appear on the screen.Voltages can be read at the ribbon connector or at test locations on the board (typical 16.74V, 3.3V, -5V and 28V)
          • CapLeaker
            Leaking Member
            • 8300
            Originally posted by JDC
            ON
            -.009
            12.13
            12.13
            -.01
            24.48
            -.011
            3.51
            3.51
            3.104
            OFF
            0
            .009
            .009
            0
            .006
            0
            3.55
            3.55
            0
            P201
            GND GND
            12V N.C.
            12V 12V
            GND GND
            24V 24V
            GND GND
            3.5V PD1M2
            3.5V PD1M1
            PWR-ON DRV-ON
            O.k., you measured GND, 12V, 12V GND, 24V, GND, 3.5V, 3.5V and PWR-ON.
            Where are the GND, NC, 12V, GND, 24V,GND, PDIM2, PDIM1 and DRV-ON measurements?
            • JDC
              • May 2015
              • 273
              Yikes! I see what I did wrong now. I'll get back to you. Thank you for being patient.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #27
                Did you manage to follow the wiring back from the Tcon fuse back to any component on the main board. You said earlier that the 12V on the Tcon fuse was missing?
                • JDC
                  • May 2015
                  • 273
                  I haven't yet, no. You are referring to the F1 fuse on the TCON?
                  • CapLeaker
                    Leaking Member
                    • 8300
                    yes, he is.
                    • JDC
                      • May 2015
                      • 273
                      yes, he is.
                      • JDC
                        • May 2015
                        • 273
                        While the TV is on, placing the neg. probe on either side of TCON's F1 fuse, and the pos. probe on the very first pin (on the left) on the still connected TCON cable, I get a reading a 12.13 VDC.
                        • JDC
                          • May 2015
                          • 273
                          This is good information. I'm not sure if I'm brave enough to try it yet. Thanks!
                            LG EBT62421329 (EAX65049105(1.1)) Main Board for 47LN5200-UB
                            http://www.shopjimmy.com/lg-ebt62421...7ln5200-ub.htm
                            Is this your main board?
                            Check the resistance between BOTH ENDS the inductor L1100 to the T-CON fuse to make sure it has <1 Ohm resistance.
                            Check the DCV (ref. to chassis GND) of all 3 legs of Q409 when TV is OFF and when TV is turned ON.
                            Pictures provided by shojimmy.
                            "While the TV is on, placing the neg. probe on either side of TCON's F1 fuse, and the pos. probe on the very first pin (on the left) on the still connected TCON cable, I get a reading a 12.13 VDC."
                            BTW, the readings should be done with Black probe to the chassis GND, not on the parts.
                            Fuse shows <1 Ohm for sure?
                            • JDC
                              • May 2015
                              • 273
                              While ON:
                              GND: 0 GND: 0
                              12V: 12.13 N.C.
                              12V: 12.13 12V: 12.13
                              GND: 0 GND: 0
                              24V: 24.47 24V: 24.47
                              GND:0 GND: 0
                              3.5V: 3.52 PD1M2: -.001
                              3.5V:.52 PD1M1:.984
                              PWR-ON:3.111 DRV-ON:1.010
                              • JDC
                                • May 2015
                                • 273
                                Looks to be it.
                                See attached. Are you referring to the circled component? If so, it measures -14.44 with every combination of probe placements (wanted to be thorough). Not sure I did this right.
                                Are you referring to IC409 on the main board? If so:
                                OFF
                                1.840 0
                                _________
                                .023
                                ON
                                3.42 0
                                ________
                                3.74
                                ON and OFF shows 00.3
                                  How about Q409 that have marked for you to test pin 1~3?
                                  https://www.badcaps.net/forum/attach...0&d=1461687797
                                    BTW: 'Quote:
                                    Do you know how to use the meter? -14.44 is what? Volt or Ohms, and are you measuring the Ohm when TV is plugged into the outlets? Is that the way you also check the fuse on the T-CON?
                                    No power should be applied to the TV when makes resistance checking.
                                    • JDC
                                      • May 2015
                                      • 273
                                      how about q409 that have marked for you to test pin 1~3?
                                      off
                                      .005 .006
                                      0
                                      on
                                      12.11 1.784
                                      12.11
                                        Where are the pin numbers?
                                        TV off
                                        Pin 1 = ???
                                        Pin 2 = ???
                                        Pin 3 = ???
                                        TV ON
                                        Pin 1 = ???
                                        Pin 2 = ???
                                        Pin 3 = ???
                                        • JDC
                                          • May 2015
                                          • 273
                                          So when checking resistance, does that mean unplug the TV or it being in an OFF state is okay?
                                          • gavric
                                            Vizio M70-C3 Half picture is bad, main board on its last leg?
                                            by gavric
                                            Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                            When tv powers on vizio V logo shows nice on whole screen. picture 1
                                            When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                            When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                            When i click video to start playing picture goes black(like when you change...
                                            09-02-2021, 08:55 PM
                                          • EazyBone
                                            Samsung QN82Q70RA backlight mystery
                                            by EazyBone
                                            I picked this up and it had picture but no backlight. I was somewhat familiar with his TV as the LED driver fails a lot on this model. But when I tested the LED driver it had all the voltages necessary. I even had a spare one to try out just in case and that one did not solve the problem either.
                                            I tested all the LEDs before pulling the screen apart but ended up pulling the screen apart anyways to further test them. Every one of them tests at 90 volts with the tester. They all light up. I replaced a couple as seen in the picture because I had extra and I accidentally popped the cap...
                                            04-23-2025, 06:15 PM
                                          • signal.quest
                                            Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                            by signal.quest
                                            I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                            03-17-2024, 10:14 AM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
