LG 47LN5200_U: PWR, MAIN, and all LEDs replaced, no picture
  • JDC
    • May 2015
    • 273
    Ugh. I'm in a hole.
    When my friend gave me this TV, the LG 47LN5200-UB would blink when it was powered on and nothing more. I blindly replaced the power board and main board. No change.
    Further research showed that this model likes to blow LEDs. Sure enough, when I took in further apart, a couple LED strips were dead along with random other LEDs. I ordered a kit and replaced them all. Now the TV lights up and stays on, but nothing else. No picture.
    What else can I look at here? I'm already a couple hundred dollars in the hole but I've learned a lot, so it's worth it in my book.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 47LN5200_U: PWR, MAIN, and all LEDs replaced, no picture
    Can you return the items even if there is a small returns charge otherwise put them up for sale to recover some of your costs.
    • JDC
      • May 2015
      • 273
      I could but I'd rather exhaust every option first. This was my first LED replacement and I'm rather proud that I didn't destroy it, lol.
        All the cables are properly back in place? You have DCV on the T-CON fuse?, etc.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          So are you saying you no longer have a blinking standby LED and the backlights are definately on when viewed from the rear of the set, absolutely no doubt about the leds being on?
          • JDC
            • May 2015
            • 273
            @budm I've literally double checked every connection. The TV comes on, the screen illuminates, and I hear static. As for checking the TCON fuse, can you be more specific?
            I just wish there was a way I could test to see if the panel is garbage before I throw a new TCON board in it.
            @dick_barton I have no doubt the LEDS are on. When I replaced the LED strips (all of them), it lit up like Christmas Eve in Vegas. They are on even after I put it back together (I'm rather proud of that! )
              We need to see the pictures of the whole back side of the TV to see how all the boards are connected together, then we need the picture of the T-CON board.
              • JDC
                • May 2015
                • 273
                Will do by Monday. Thanks!!
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Delete.
                  • JDC
                    • May 2015
                    • 273
                    Originally posted by ReeceyBurger123
                    Delete.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Originally posted by JDC
                      Didnt mean to comment on thread.
                      • JDC
                        • May 2015
                        • 273
                        Here you go. I took a closeup of the TCON fuses as well.
                        • JDC
                          • May 2015
                          • 273
                          Bump.
                          • CapLeaker
                            Leaking Member
                            • 8300
                            Umm... first off your pics are blurry.
                            Now there is a ribbon cable going from the PSU to the main board. There is a pin out on the PSU. Measure all those with the TV on and off and post the measured DC voltages with the corresponding pin out name.
                            Also try to turn on the TV and measure both sides of F1 on the Tcon against cold GND.
                            Report back.
                            • nicholas1110
                              • Aug 2012
                              • 127
                              • usa
                              I have had the exact thing happen to me on one of the first ones I've done LEDs on this model. Here is what happened to me. I take the tv down to the LEDs. Repair the LED strips as needed. I turn the tv on to check that all LEDs are working and rest the tv on the bottom edge. No I did not disconnect the tcon from the main board l, so when I tipped the tv up the ribbons to the panel touched the metal frame and shorted a component out on the main board. It was near the lvds connections smd square ic chip. So if you left the tcon plugged in and the ribbon cables in the tcon and tipped the tv up I would almost bet you shorted out the main board or something on the tcon from the ribbons touching the metal frame. If you took the ribbons off or unplugged the lvds cable then disregard my suggestion
                              • JDC
                                • May 2015
                                • 273
                                Report back.
                                Using the main board pic I posted above as reference, from left to right:
                                ON
                                0
                                12.13
                                12.13
                                0
                                24.47
                                0
                                3.47
                                3.47
                                1.107
                                Off (but plugged in)
                                0
                                .007
                                .007
                                0
                                .004
                                0
                                3.55
                                3.55
                                0
                                F1 fuse on TCON:
                                ON .014 both sides
                                OFF 0 both sides
                                • JDC
                                  • May 2015
                                  • 273
                                  I took the ribbons off the TCON when I was taking it apart but the connection from the TCON to the main board was left alone.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    You appear to have no TCON voltage, so no picture. You need to follow the wiring back to the mainboard and find the supply. Use your meter to trace the connection from the TCON fuse down to the mainboard. The TCON supply is probably supplied from a switched transistor or mosfet that I suspect has been blown.
                                    Edit
                                    Please can you provide some sharp picture of your main board which would be of help.
                                    • Diah
                                      • Feb 2013
                                      • 6427
                                      from yours T-CON photo it show to me the left ribbon cable not correct sitting at the panel socket., take them both out and check the Gold pins of them, then reset them correct, as they labeled with hand writing they seem had story.
                                      • CapLeaker
                                        Leaking Member
                                        • 8300
                                        ON
                                        0
                                        12.13
                                        12.13
                                        0
                                        24.47
                                        0
                                        3.47
                                        3.47
                                        1.107
                                        0
                                        .007
                                        .007
                                        0
                                        .004
                                        0
                                        3.55
                                        3.55
                                        0
                                        F1 fuse on TCON:
                                        ON .014 both sides
                                        OFF 0 both sides
                                        Those are only half of the pin outs. There are 18 of them in total. We need all of them plus the pin out name!
                                        However... there is no voltage going to the Tcon. no voltage there, no pic. Maybe disconnect the tcon and see if the voltage re appears on the connector.
                                        • gavric
                                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                                          by gavric
                                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                          When i click video to start playing picture goes black(like when you change...
                                          09-02-2021, 08:55 PM
                                        • EazyBone
                                          Samsung QN82Q70RA backlight mystery
                                          by EazyBone
                                          I picked this up and it had picture but no backlight. I was somewhat familiar with his TV as the LED driver fails a lot on this model. But when I tested the LED driver it had all the voltages necessary. I even had a spare one to try out just in case and that one did not solve the problem either.
                                          I tested all the LEDs before pulling the screen apart but ended up pulling the screen apart anyways to further test them. Every one of them tests at 90 volts with the tester. They all light up. I replaced a couple as seen in the picture because I had extra and I accidentally popped the cap...
                                          04-23-2025, 06:15 PM
                                        • signal.quest
                                          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                          by signal.quest
                                          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                          03-17-2024, 10:14 AM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
