Toshiba 55ZV650U REGZA sound but no picture
  • eztiger12
    • Apr 2016
    • 44
    I will try to give you as much information as possible in order to figure out the issue I have presently.
    Like the tilt says its a Toshiba 55ZV650U REGZA.
    Manufactured October 2009 in mint condition.
    The problem: I got sound but no picture!
    I would have to open and close the TV once or twice in order to get a picture and the TV worked normal.
    Later.... the on and off became 5 - 6 time and then nothing at all......no picture no matter how many time I turn it on or off.
    I can turn on the TV now ...the TOSHIBA sign lights up, the sound comes on but still no pictures.
    I have done the flash light test in a dark room but I still cannot see a picture.
    I can see light when I have the back cover off when TV turned on and I can see the front screen go front pitch black to lighter black or very dark grey.
    I have been doing a lot of reading but I m just getting more confused on what it might be.
    I dont want to change pieces just for the sake of it.
    I would really appreciate it..........
  • CapLeaker
    Leaking Member
    • 8326
    Re: Toshiba 55ZV650U REGZA sound but no picture
    In order to get around that, you would have to provide clear, high res, straight shot pictures of your PSU and main board. Then you need a digital multi meter, so we can measure things and determent the fault.
    • eztiger12
      • Apr 2016
      • 44
      Ok will do.......I ll try to get that done as soon as possible. If anyone else wants to kick in feel free.
      • eztiger12
        • Apr 2016
        • 44
        I have taken several picture and attached them to this post to help solve the problem. I thought I had this one solved and replaced the T-com but nothing doing. I does the exact same thing no change.
        What I have checked so far was the standby light lights up in front of the TV.
        Standby volts is at 5 volts on the multimeter.
        There is 24 volts coming go of the board to the backlight. (I can see the light go on as well once the back cover is off).
        I checked the rectifier output and its at 106.5 steady ( saw on youtube that maybe it should be at 160V but not sure if he was working on the same model).
        Rectifier output for the a/c is 117.8
        I am really hope for everyone input so I can solve this issue.
        I also checked the fuses and they look fine.
        Anxious to get some replies.
        Thanks in advance.
        • eztiger12
          • Apr 2016
          • 44
          If any other pictures are needed please let me know.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            The set looks as though it's been worked on before looking at the amount of heatsink compound around some of the components.
            What voltage do you have on both sides of the white ceramic fuse on the Tcon board
            What volatge do you have on the 12VLCD pins.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              The mains does seem low. Is one of the large caps (C821) starting to bow on top?
              What is the dc voltage across the legs of C820 & C821 which are rated at 450V dc.
              • eztiger12
                • Apr 2016
                • 44
                Re: Toshiba 55ZV650U REGZA sound but no picture (Pix of boards added)
                Just wanted to in the title that I have added pictures of my boards in order to get some help......sorry and Thanks
                • Diah
                  • Feb 2013
                  • 6435
                  let your room dark and use light torch on the screen and tell us if you can see some effect of picture or Menu any els
                  • CapLeaker
                    Leaking Member
                    • 8326
                    are the back lights on and no picture, or you got no picture because the back lights are off?
                      "I checked the rectifier output and its at 106.5 steady ( saw on youtube that maybe it should be at 160V but not sure if he was working on the same model)."
                      Where did you put the black probe of the meter, the chassis or at the negative leg of the cap? It looks like you are using the chassis as the GND.
                      • eztiger12
                        • Apr 2016
                        • 44
                        To answer Dick Barton ......
                        if you refer to the 4th picture you can see C821 and I noticed an ever so slight bow compared to the other large ones. But like I said minimal.
                        How do I check this ...."the voltage across the legs of C820 & C821 which are rated at 450V dc."
                        Budm
                        I put a probe on each leg.
                        Capleaker / Diah
                        Backlights are on but there is no picture.
                        Dick Barton
                        help me out here plz....
                        Where do I check the voltage on both sides of the white ceramic fuse on the Tcon board. Where is or which is the ceramic fuse?
                        where do i check the voltage on the 12VLCD pins.
                        Please guide me and Ill supply the results ......I am not a pro but I manage to do a lot with instructions, youtube, the internet and a lot of reading on this forum.....lol
                        Thanks guys for the input so far.
                        • eztiger12
                          • Apr 2016
                          • 44
                          If you enlarge image 6 or 8 on the rectifier, I got that reading by putting a probe on each of the squiggle lines ......a probe on each one of those interior legs.
                          • eztiger12
                            • Apr 2016
                            • 44
                            Just wanted to add that the TV was bought brand new in a sealed box and never had an issue with it until now. Not sure if that changes anything.
                              The ~ pins are the Line and Neutral AC input pins for the bridge rectifier and it should show 120VAC.
                              • eztiger12
                                • Apr 2016
                                • 44
                                Sorry ....my bad...your totally right. I get a reading of 117.8 on those pins.
                                But I get a reading of 106.5 on the pins just on the outside of those that are identified with a "-" and "+" signs.
                                Sorry about that.
                                • CapLeaker
                                  Leaking Member
                                  • 8326
                                  For those you did set the meter to measure DC volage? 120x1.414=169.68V
                                    You should measure right between the +/- legs of the main filter cap.
                                    • eztiger12
                                      • Apr 2016
                                      • 44
                                      Yes sir I did .........but I will double check tomorrow but Im 99 percent sure.
                                      • eztiger12
                                        • Apr 2016
                                        • 44
                                        Budm.........you got to help me out here. I am not sure what exactly you want me to check. Can to guide me please. I would like to more tests on it tomorrow morning even though its Mothers day........not sure if the wife will aprouve lol
                                        • jord4231
                                          Toshiba 37AV500A Regza TV good power supply no sound no picture
                                          by jord4231
                                          Hi Everyone,
                                          I'm working on a Toshiba 37AV500A Regza TV.
                                          The issue:
                                          TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                                          The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                                          I checked the PSU voltages and everything looked good.
                                          No bulging caps or signs of heat.
                                          24v aud = 24.41v
                                          12v = 11.98v
                                          5v = 5.062
                                          p_o/f = Goes high...
                                          03-29-2022, 09:21 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
