Samsung le32a456t1d. Bn44-00213a rev1.1 glue fault
  • Cobblers
    • Jan 2016
    • 90
    • Uk
    Hello all. So i have this samsung for a few weeks ive been trying to work through the faults. I have made a little progress but ive stalled with it now.
    So when i first opened it up i found the main fuse blown and a couple of wires links next to the main cap melted under the glue. It had also melted the leg on cm810. After more checks i found 2 shorted mosfets and also the bridge rectifier was shorted.
    I replaced all them components. The fuse no longer blows and i have 5.22v standby. I have the standby light if i turn the set on i get five flashes from the front then it just turns solid red again. Also if i try to turn the set on again the red led does not respond unless i disconnect the mains for about 10 seconds and then plug back in.
    One thing i have noticed is i always seem to have 385v on the main cap from the instant i plug in the mains power? Im thinking the must still be more damage from the shorts but could do with some guidence in tracking them down. Thanks in advance.
  • comptek
    • Aug 2013
    • 606
    Re: Samsung le32a456t1d. Bn44-00213a rev1.1 glue fault
    have you removed all the brown glue?
    have you checked the standby transistor 1 o'clock to the power connector make sure its ok and no glue on it you may have to reset eeprom on mainboard
    • comptek
      • Aug 2013
      • 606
      this is it
        BN44-00213A diagram provided by tom66.
        • Cobblers
          • Jan 2016
          • 90
          • Uk
          I removed all the glue best i could. Ok ive checked this. I tested on diode test. Its open circuit between emitter and collector both ways. It has .62v from emitter to base one with positive lead on base, open with positive on emittor. And it has .62v base to collector with positive lead on base open the other way. Does that seem ok?
            Can we see good clear straight shot pictures of the top and bottom sides of YOUR board?
            • Cobblers
              • Jan 2016
              • 90
              • Uk
              Ok how do these look.
              • howardc64
                Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                by howardc64
                • Prior owner tried a replacement main board. No difference.
                • Samsung 2x red blinking standby LED = panel fault
                • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                07-19-2025, 10:54 PM
                09-07-2024, 05:50 AM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
