VIVAX LED TV 32LE60 backlight problem
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hello, i got this LED TV with bad backlight. I disassable it and TV has 2 set of line with 10 small SMD LED diode. (total 20 diodes) I found that 2 diodes were dead (one on each line). I found similar LED diode and replace them. I tested the whole line with 30VDC and it worked, but when i connect to tv LED burned.
    The output of main board is 60VDC when turn on backlight, what is the problem here is the problem that LED i use is not enough Amps?
    ...the quieter you become the more you are able to hear...
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: VIVAX LED TV 32LE60 backlight problem
    Was it the replacement leds that burnt?
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      yes, only those 2 led i replaced burned. I think they cannot handle that current. I check the other LED they handle 0.08A at 3V. The one i use is less than 0.01A at 3V so i think that is the reason why they burned.
      The LED are 2.8mm x 3.5mm
      Do you know where i can find them online
        You want at least 300~400mA range LED. They drive those LED hard so they fail, you should turn down the backlights level after are fininsh repairing.
        What does the LED look like?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          yes your replacements were rated for too low current.
          post pics.
          i had a 55" samsung with bad leds.they were 5630 type run at 150 ma.
          i found some in bulk on ebay cheap.they were yuji high cri rated 250ma.
          but polarity reversed and 6000k. originals were way cooler .it looked better to the customer than a newer set.i am glad i got the reel of 5000 once i figured out the real cost.
          seller didnt know what he had.
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            It is 2835 LED, i think that 80mA will be ok. I cannot find 2835 LED that is above 100mA
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Read what Budm said. They push the Leds up to 400mha in these cheap Tv's. Look up for "Led strips out smashed Tv" on ebay and do the stacking method of repair.
                Can we see the pictures of the LED strips and the LEDs?
                http://www.aliexpress.com/wholesale?...=LATWT470RELZK
                http://www.aliexpress.com/item/100PC...6-b17a37c8c856
                • Dobrowol
                  Asus GA402RK keyboard and kb backlight problem
                  by Dobrowol
                  Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                  04-28-2025, 04:30 PM
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                  🛠 Original Issue
                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • ononos
                  LG M2362DP Backlight problem
                  by ononos
                  hello everyone!
                  As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
                  I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
                  So i decided to try to...
                  03-12-2023, 05:05 AM
                • fanaticgames
                  Samsung UE32D4010 Backlight problem, led ok
                  by fanaticgames
                  hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                  02-22-2023, 09:46 AM
                • Honziq
                  Backlight problem - Asus M3200WU, board Gapal LA-L291p
                  by Honziq
                  I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
                  I was repaired many backlights before but this design i will not understand.
                  For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
                  Can someone explain me please what to do, what to check?
                  Thanks....
                  11-20-2024, 01:24 PM
