samsung ue50h5570ss
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    samsung ue50h5570ss
    I have a problem with a samsung ue50h5570ss ...
    When i connect the main board with the power supply,the backlight goes out,
    and it does not react on power button ...
    I have changed the aoz3015PI,be cause he was blown up ...
    any advice
    thx
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Re: samsung ue50h5570ss
    Forgot to write that when i connect only the power board the backlight goes on
    someone knows what is wrong ???
    thx
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      you have a main board problem.
      • nbdy
        • Aug 2015
        • 162
        • Croatia
        Is it possible to fix it,or replace it is the only way??
        I have the BN41-02156A BN94-07369Y board revision ...
        Could I replace it with this one :
        BN41-02156A BN94-07369C
        the only difference i see is that the board does not have a sat connector on the tuner (I dont need it at all)
        • raileanu
          • Sep 2015
          • 128
          The display connect might be also different.
            09-07-2024, 05:50 AM
          • KYBOSH
            Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
            by KYBOSH
            I picked this one up today.
            Previous owner says no signs of life.
            TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
            Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
            The TV model is QN65LS03BAFXZA - version: CB06
            The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
            I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
            Will keep you all...
            04-05-2025, 08:32 PM
          • atkallu
            Samsung One Connect Box SOC1001N vs SOC1004N
            by atkallu
            I am asking have somebody information about Samsung one Connect boxes compatibility ?
            So, can I use SOC1001N box on the TV which have SOC1004N box, is it compatible ?
            SOC1001N box has been worked with Samsung QE55Q8 and the SOC1004N box has been used with Samsung QE55Q9.
            Boxes part numbers are the same: BN68-08730A-00.
            07-09-2025, 01:54 PM
          • An-klamm
            Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
            by An-klamm
            Hello!
            I have a TV that I can't get any further with.
            It is a Samsung UE 55HU8590 with one connect box.
            When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
            As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
            Since the TV works without ocb, I assume that it can't be the PSU?!
            I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
            Is there...
            12-04-2023, 01:35 AM
          • AlexVG
            SAMSUNG UE65HU8500 ONE CONNECT pinout connector request
            by AlexVG
            I came across with
            SAMSUNG UE65HU8500
            ONE CONNECT BN41-02135
            Chassis GOLF_UHD_1MP_JACK
            TV can not recognise ONE CONNECT box, so I need to know the pinout of the CN 3301 connector.
            Moreover, on the main is written A5V. However, cable connected this pin to the GND.
            Maybe somebody have an experience with the same issues?
            I need your help.
            Thank you....
            06-08-2025, 06:49 AM
