LG42LA620V no backlight
  • sordids999
    • May 2013
    • 2161
    hello
    Backlight flashes once on start up then no backlight but with a torch shining onto the screen you can see images ok
    voltages seem fine also 58 volts going to the panel/LED`s not dropping
    anyone come across this before or is it a bad led ?
    thanks
  • Diah
    • Feb 2013
    • 6435
    Re: LG42LA620V no backlight
    take it in parts till strips of LED, led shorted or open.
      What is the Voltgae rating of those two lyrics cap by the bottom left of #2 picture where the boost converter for the LED driver circuit is?
      58V seems low but I cannot tell yet until I have a chance to look closer at that boost converter section later on, I expect it to jump up higher than 58V at first and then drops down to 58V, but as history of LEDs backlights I will not be surprised if you have bad LEDs.
      • sordids999
        • May 2013
        • 2161
        hi budm
        do you mean the two caps i have circled in the picture ?
        and yes when the tv first boots up voltages are 59.8 volts then drops to 58.4 volts and stays steady
          NO, the two brown electrolytics caps to the left side of the board, and actually there are six brown lytics caps in the LED driver sections and also two inductors for boost converter circuits so the LEDs are not connected in one large LED string.
          According to the Voltage chart next to the LED connector, the Voltage for the LED is 105V, 0.313A? I cannot see the chart that clear.
          You need to leave the red probe on the L+ and black probe on GND then turn on the TV and watch the meter to see how high the Voltage goes up too, you need to do that twice since you have two L+.
          • orinoco8
            • Jan 2016
            • 26
            not sure whether this is allowed here: maybe you want to try the method posted on
            http://www.forums.toshiba.com/t5/Tel.../154712/page/2
            post 35.
            • sordids999
              • May 2013
              • 2161
              correct
              105V, 0.313A HIGH
              70V, 0.313A LOW
              and yes 105 volts when i first turn the tv on then drops so its pointing to a bad led i think
              • sordids999
                • May 2013
                • 2161
                Fixed :
                luckily had some spare LG LED strips from a cracked screen tv testing as we speak
                  Thanks for the follow-up on the repair, another failed LED backlights.
                  The trick when measuring the LED supply Voltage is to leave the probe on the Voltage supply pin for the Anode of the string before turning on the TV and have good meter that can response fast enough to capture the Voltage rise before dropping down due to protection circuit kick in. 58V is the feeding Voltage to the boost converter circuits.
                  BTW, what are the Voltage rating of those caps I asked?
                  • sordids999
                    • May 2013
                    • 2161
                    No budm sorry i could not see any ratings on them
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      The two brown capacitors C801 & C802 are both 33uF 200V
                      • triplefour
                        by triplefour
                        09-13-2023, 10:43 PM
                      • hollox123
                        ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                        by hollox123
                        Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                        1. Laptop keyboard doesn't work
                        2. The backlight on the laptop keyboard doesn't work
                        3. The x2 side LEDs (red) on the laptop don't work
                        The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                        I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                        But I am strongly aiming that it is somehow a BIOS-related problem,...
                        05-11-2025, 08:05 AM
                      • signal.quest
                        Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                        by signal.quest
                        I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                        03-17-2024, 10:14 AM
                      • DanPoka
                        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                        by DanPoka
                        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                        02-15-2025, 05:05 AM
                      • Comp_Pro
                        No Backlight Macbook A1990 820-01041
                        by Comp_Pro
                        Hello all,
                        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                        Tests performed:
                        There is no backlight even with a good screen.
                        Backlight IC is receiving the correct support voltages.
                        Fuse F8400 ok
                        Current sense resistor R8400 ok
                        Backlight IC is receiving 3.3V on enable pin.
                        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                        Backlight IC receiving 5V from PP5V_G3S
                        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                        05-06-2024, 10:23 PM
