Wharfedale LT26K1CB
  • 6BW6
    • Jan 2015
    • 55
    Wharfedale LT26K1CB
    Wharefdale LT26K1CB
    Stuck on power 'ON' no back lights, No sound.
    I know it's a cheapo.... no bulging caps. in psu, I changed them all the same using low ESR 105deg.C types. Voltages are up and running and appears 'hash free'.
    I disconnected the keyboard in case of a sticky or leaky button to no avail. I can force the back lights on by the 'Bon' terminal and they look pretty healthy. Anyone know how to apply a CPU reset.
    Thanks Dave.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Wharfedale LT26K1CB
    What Psu does it have ?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Just repaired a Wharfdale LT37K1CB model.
      Power supply board JSK 422B-050A
      The fault was identical to your description and was traced to C22 on the power supply. 47uF 35V capacitor had gone high ESR.
      • 6BW6
        • Jan 2015
        • 55
        The power board is a PSM143-310-1-R.
        I did change the larger caps. but not the smaller ones, the supply appears to be 'hash free' when checking on scope. The voltages are within spec the last time I measured, was casting my eye's on the Eprom.
        Might be worth my while swapping all the 47uF..... at least I'll have a recapped psu.
        Dave
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          So are all your supplies from the power supply within spec?
          You say you can force your backlights on.
          What do you have on Power_ON pin when you attempt to switch the set out of standby?
          • 6BW6
            • Jan 2015
            • 55
            The power ON terminal is stuck 'ON', the back lights are stuck OFF irrespective of any button or remote action being issued. The psu voltages are within spec. plus a couple of 100mV either way, I couldn't see any ripple or hash that caused me to worry, I did change the 'usual' high value caps. in the power supply to be sure but not the 47uF as been suggested but will do at the next opportunity.
            For curiosity I tried with the Tcon disconnected, CPU crystal is OK and all the regulators on the main board appears to be up and running (Haier MSD109CL-V400), seems it's all down to CPU, Eprom or a bus line clogged up.
            Thank you for your interest, Dave.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Probably epprom fault common on them Haier junk boards.
              • CapLeaker
                Leaking Member
                • 8211
                I think so too.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Have you tried freezing the EEprom as suggested when considering an EEprom fault to see if you can boot up the TV?
                  • 6BW6
                    • Jan 2015
                    • 55
                    Eprom was the next thing I was casting evil eyes on. No, not tried freezing, I'll give it a try when I get a new can of the stuff..... think I'll gamble on swapping it, I'll let you know how it goes in a day or two. Dave
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Have you solved the problem?
                      • 6BW6
                        • Jan 2015
                        • 55
                        I fitted a eprom and got the dump files.... I could now switch it off and on and now the backlight flickered faintly just before tripping to stand by..... I replaced the SMD zener on the Tcon board marked 'CCD KE' which was s/c, I got one from a scrap Samsung Tcon board.... from what I can find out this is a 5V zener.
                        Before fitting the SMD zener I thought go on lob a 5V wire ended zener in to see what happens, I was expecting to see a puff of smoke and a load of Indians with their tomahawks doing a war dance .... the telly burst into life all I had to do was retune, so to keep things nice and orderly I fitted the SMD device I robbed..... all I had to do was a retune.
                        Nice picture but pity about the sound, I've heard worse though.
                        Thank you all, any problems with these Tcons check the smd zener near the ribbon connector - sorry didn't make a note of the component number, there's only one and it's easily seen.
                        Dave
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Glad you sorted it out. Another successful repair.
                          • Vusal
                            CPU replace | OEM Hash key poblem
                            by Vusal
                            first of all hello everyone
                            If there is a short circuit on the motherboard of the HP laptop. The CPU was broken (i3-10th) I found a donor motherboard on ebay and replaced the CPU.
                            The CPU on the donor motherboard had the OEM Hash key. But I did not check the OEM Hash key before ordering the donor motherboard.
                            Normally, after changing the CPU, the motherboard started and the white LED light on the DC jack was blinking.
                            The motherboard was in reset state and the current drawn was 60mah.
                            I checked the BIOS information and added the OEM Hash key on the donor motherboard...
                            04-04-2024, 02:30 PM
                          • Francesc V.
                            Christmas lights - Something I am doing wrong
                            by Francesc V.
                            Hi:
                            i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
                            I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
                            If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
                            Could...
                            03-11-2023, 07:38 AM
                          • bialag
                            Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                            by bialag
                            I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                            Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                            03-25-2025, 05:56 PM
                          • gabrielA7
                            IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
                            by gabrielA7
                            Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
                            I saw that the room LED lights up only when the screen is connected, so quiet.
                            We have all the power supplies, even processor, 1.8V
                            One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
                            I suspect that there may be some leak in the processor.
                            Anyway, when I press the power, it...
                            10-29-2024, 06:48 AM
                          • evilkitty
                            When your mom is complaining about her new cheap lights
                            by evilkitty
                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                            07-23-2024, 01:27 PM
