Panasonic TH-42PZ80BA. 10 blinks
  • Fleckers tv
    Fleckers TV
    • Nov 2015
    • 89
    Hi peeps. Couldn't find a thread for this but if there is one please link. I don't usually repair these but I got this one under misleading circumstances, don't get me wrong I love pannys but find them a pig to work on, but with some help , I should get this one running again.
    Only getting 4.9v during blinks from power supply, if I disconnect Left buffer Y us. I still get 10 blinks. If I disconnect X main (right buffer ) I get nothing , as us usual Google is awash with confusing info saying it could be any board, can't find any shorts on the buffer boards so, can you help
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Panasonic TH-42PZ80BA. 10 blinks
    SMPS Transformer fuse OK....?
    TELEFIX
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      You dont like to work on them. So you dont like a challenge then ? Or to be able to fix an awesome Tv ? There are two smd caps on the controller boards that tend to fail will link repair kit.
      • Fleckers tv
        Fleckers TV
        • Nov 2015
        • 89
        I love a challenge, but these buggers weigh a ton, and I have 2 still to repair both with 7 flash error codes, one needs a main board which I can't find and one needs a ysus which is on the way, I think these tvs were among the bes=t quality made, I have several, but I have not got great Plasma experience
        • Fleckers tv
          Fleckers TV
          • Nov 2015
          • 89
          yes all board fuses are fine, thank you for replying guys, keep it up, there are all the boards for this on ebay, buts that is cheating
          • vinceroger69
            • Mar 2012
            • 6714
            https://www.youtube.com/watch?v=LjpGKaBt8hg
            • Fleckers tv
              Fleckers TV
              • Nov 2015
              • 89
              This Diode D054 is reading as shorted , on the PCb
              Could this be the lone culprit
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Thats a snubber diode for the tarfo it should show shorted.
                • syaoran123
                  • Jun 2014
                  • 178
                  There are 2 chips on the power supply which look like mini circuit boards labelled mc201 and mc301. Use electronic freeze spray to cool them down, then power it up to see if it works. It may or may not work using this test method.
                  Of course vinceroger69 has posted a very good link on how to rework these chips. And instead of SMD capacitors, you can use the aluminium through hole capacitor kind.
                  Hope this helps
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    post 2 alastair means this fuse i think
                    • Fleckers tv
                      Fleckers TV
                      • Nov 2015
                      • 89
                      Yes I have seen that video before, I have tried freezing the ic's 201 and 301, but no change, in fact its stopped the relay clicking now, but still flashing green with the 10 blinks shortly after. shame , I was getting excited then,
                      Thanks guys, any other tips please share, I am determined to get this up and running for my Birthday, which is tomorrow,
                      How sure do we think its the powerboard, isn't there a way of getting this set to come up with the white rasta to test the powerboard ??
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        did you freeze the ics? when i repaired my set i froze just the two very small smd caps as shown in my first video and the set came on so i just replaced the capacitors it maybe worth still swopping the two capacitors though on your set to rule them out.Does your set have that thermal fuse like in my second video link did it test ok?
                        • Fleckers tv
                          Fleckers TV
                          • Nov 2015
                          • 89
                          Hi Vinceroger, both your links are for the same vid, did not notice the caps one, would love to try that next...
                          thank you
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            https://www.youtube.com/watch?v=mBw8...&nohtml5=False
                            have you checked this?
                            and in the other video 11.00 minutes the 1uf capacitors hes removed/changing freeze them and see if the set starts
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Try freezing them Ics and the 1uf ceramic caps for them also check the thermal fuse that can fail too causing non intermittent 10 blinks. Also like the lighting set up haha
                              • Andre Gilbert
                                by Andre Gilbert
                                Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                11-20-2024, 08:52 PM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • Biruslapio
                                Panasonic P58V11B 8 and 12 blinks error "fix"
                                by Biruslapio
                                Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                04-13-2021, 07:13 AM
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • jm1234
                                Panasonic plasma TX-P42ST50 - 6 blinks
                                by jm1234
                                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                I checked that board for any obvious faults...
                                05-22-2024, 06:59 AM
