Sharp LC-52LE640U flashing logo.
+ More Options
Posts
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Re: Sharp LC-52LE640U flashing logo.
    Yes I saw it thanks. Seems like none are available anywhere.
    • robotron
      • May 2016
      • 3
      Did you ever find any LED strips for your Sharp?
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        Nope. I got rid of the tv. I saved the left strip. The right one was the bad one.
        Which do you need?
        • robotron
          • May 2016
          • 3
          Well, I haven't torn it apart yet, but about 1/4 of the screen on the left side is dark. The darkness comes up from the bottom and fades about 6 or 7 inches up.
          I've done a bunch of reading up on it and watched a couple of videos. So I'm pretty sure its the LEDs. Just in case it is, what would you want for your LED strip?
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            If you cover shipping plus $10? Is that reasonable?
            • robotron
              • May 2016
              • 3
              I sent you a PM. Thanks.
              • jerrybrownlee
                • Nov 2015
                does anybody know whwre i can get individual leds for SHARP LC 52LE640U LED BACK-LIGHT STRIPS, Part# RUNTK5208TPZZ and RUNTK5209TPZZ
                • macsnjets
                  • Oct 2017
                  • 5
                  I have the same question. Does anyone know a good resource to learn identifying surface mount LED's ?
                  • dmcabs
                    SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
                    by dmcabs
                    Hey guys,
                    I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
                    This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
                    FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
                    I'm a bit rusty but still have ability to dig right down.
                    I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
                    09-21-2024, 11:09 AM
                  • JunkmanJimbo
                    sharp lc-65ub30u plays but screen is flashing on and off
                    by JunkmanJimbo
                    Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
                    09-07-2024, 09:45 AM
                  • Super360
                    Vizio E701i-A3 Vizio logo flashing then turns off
                    by Super360
                    Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                    07-25-2024, 07:06 PM
                  • STKR123
                    Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                    by STKR123
                    As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                    I wonder if re-flashing the BIOS might be of any use here.
                    As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                    There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                    11-03-2024, 06:58 AM
                  • DrvLikHell
                    Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                    by DrvLikHell
                    Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                    The...
                    02-05-2025, 01:44 AM
