TEAC LEV24A1FHD replace RF socket
  • elpres
    • Apr 2016
    • 11
    So, I acquired a TV, that seems like it is actually pretty good. A Teac LEV24A1FHD.
    The issue is that it has taken a bit of a beaten and part of the RF socket has been ripped off.
    What I would like to know is if someone knows what the part number is for this particular component, where I might purchase it in South Australia (if at all possible) and any other details that might be good to know?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: TEAC LEV24A1FHD replace RF socket
    Ahh TMSD junker Tv, does the lid of the tuner can come off ?
    • elpres
      • Apr 2016
      • 11
      I assume you mean the little metal box I photographed. I'll get into it when I get an opportunity. May not be for a day or so.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ok if you can take the lid off you might be able to replace the coil easily rather than the whole can.
        • elpres
          • Apr 2016
          • 11
          No way to get in there. Will need to remove it. Looks like it's just a shield?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Yeah probably is just the shield, the tuner Ic will be soldered on to the motherboard.
            • elpres
              • Apr 2016
              • 11
              Will have to get some de-solder braid, can't find mine. Sort of sucks, was hoping to only make one trip.
              • elpres
                • Apr 2016
                • 11
                So, I tried to heat it up but it barely melted, I went up to ~ 480 Celsius. I only have a needle point head and unless I get a new iron/ station I can't change my tip.
                Anyway, any tips or suggestions? I could cut it off to get in there, any issues doing that?
                • CapLeaker
                  Leaking Member
                  • 8126
                  Take something bigger... maybe a soldering gun, heat gun, a bigger soldering iron.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Also try adding some new solder it sometimes helps with removal of parts.
                    • CapLeaker
                      Leaking Member
                      • 8126
                      ... leaded solder has a lower melting temp, silver solder has a higher melting temp.
                      • Oldschool297
                        KM400-M REV 1.0B Socket 462. Replace capacitors.
                        by Oldschool297
                        I got a bluescreen error in Windows Vista Ultimate and after a restart i got Bios checksum error and A: error. I do not have a A: drive. Now the screen only is black, the fans and harddrives start but the screen is black. I tried my graphic card in another computer and it worked. I also tried to remove the memorys. Can it be the bios or caps? It start with the bad caps but no screen is visable. There are 6 bad 6.3v 1000uf. I got 6.3v 1500uf but i guess these won't go?...
                        08-10-2023, 04:27 AM
                      • Isabella91
                        Possible to convert eMMC Socket to a micro SD Card socket?
                        by Isabella91
                        I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
                        Read/Write a Micro SD Card from an eMMC Socket.
                        I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
                        Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
                        Not to remove...
                        01-14-2024, 05:10 PM
                      • warsztat
                        Acer AN515-57-577G JDIMM1 socket not working.
                        by warsztat
                        Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
                        11-18-2024, 09:13 AM
                      • Geomih
                        CPU socket replacement soldering profile
                        by Geomih
                        Hi All - I am hoping someone can help with some pointers (complete noob here!)
                        I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
                        My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
                        The simple stuff like a small memory module isn't a big deal because there are
                        12-11-2023, 11:07 AM
                      • Biessea
                        ASUS Sabertooth 990FX REV.2 bios chip problems, probably socket shorted?
                        by Biessea
                        Hi there,
                        I'm a technician and a computer/retro computer lover.
                        I just bought a great Sabertooth motherboard (I really love the colours and the ASUS military scheme) to install a nice FX-8320 from AMD and make a gaming computer with a Geforce GTX 970.
                        For the first time I had problems with the system, but I solved and then correctly booting, I installed Windows 10 and then I started to overclock the system. I reached a stable configuration of 4,8GHZ with 1,475v.
                        Then I saved fan configuration, and other parameters, and saved to the overclock profile...
                        03-01-2022, 03:57 AM
