Hi Sense LEDN50K20DGP Dim picture Repaired
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Hi guys,
    Another dim display solved by repairing the lamp house.
    photo 1 shows dim illumination with the last led on strip 8 not burning.
    Photo 2 shows that i swapped strip 8 with strip 12, putting the faulty led in the bottom right hand corner. lamps still burning dimly.
    Photo 3 shows the faulty led have been replaced with a 1n4148 (i dont know if this is "legal")
    Photo 4 shows leds now all burning brightly.
    The faulty led read about 1.5 megohm either way.
    A good led showed no resistance either way on my dmm's resistor setting, but illuminated when i foward biased the led on my dmm's diode setting.
    Thanks to the guys who posted the information on led & flourescent illumination.
    Re: Hi Sense LEDN50K20DGP Dim picture Repaired
    You should use 5 1n4007 in series to simulate one white LED, 1N4148 is not going to last.
    • CapLeaker
      Leaking Member
      • 8327
      better yet another LED from some junkers...
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Awesomeness, thanks for the thread
        • Grunder
          • Jan 2016
          • 323
          • south africa
          Thanks Budm, I didn't know the Led's handled so many amps, in future will use the stacking method as demonstrated in ReeceyBurgers video.
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • petersor
            Hisense 58R6E3 Backlight/No Picture Repaired
            by petersor
            Quick repair summary for those interested. I had a Hisense 58R6E3 TV that had backlights working but no picture. T-Con had 12V supply but some of the supplies on the board were 0V. Unplugging one of flat cables to the LCD display driver boards brought the supplies back up, so I figured it was a short on the LCD panel driver board. Narrowed the short down to the 15V power supply by checking the coils on the T-Con board to ground with a diode test and confirmed that all the MLCC caps on that rail all showed a short to ground. I injected 5V/1A into the 15V rail on the driver board (T-Con disconnected)...
            06-07-2024, 04:16 PM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
