LG 50ps60-UA fuzzy red/pink picture
  • bluehands77
    • Apr 2016
    • 8
    Hi, I was recently given this tv by an acquaintance. Upon turning it on at home I discovered the overall picture fuzzed out in red/pink/purple hues. It has nothing to do with inputs. After turning it on/off several times, the tv actually did work for about an hour. I needed to untangle cables behind it so I turned it off again and the red fuzzy picture is all I get now. After a day, nothing is changing. My acquaintance says that he never had any trouble with the tv whatsoever. Albeit heavy as hell, transportation between his house and mine went without a hitch so I can't see that having anything to do with the problem. As far as he knows, the power cable is original.
    After doing some internet searching it seems like this is a somewhat common problem and the general fix seems to be repairing/replacing the Zsus board.
    I'm totally ignorant when it comes to electronics and I have a tv that is small but works just fine, so I wouldn't really be interested in investing much money in repairing it. I'm just looking for advice on whether it's a good bet the problem lies with the zsus board and to put the $40 or so on a refurb since it seems fairly straight forward to replace? I realize there could be other device failures but the symptom seems to steer towards others' same experience where replacing it alleviated the problem.
    Any help is appreciated. Thanks!!!!
  • comptek
    • Aug 2013
    • 606
    Re: LG 50ps60-UA fuzzy red/pink picture
    hi can you post some pictures of the fault and of the boards inside will need you to take the back cover off "unplugged" thank you
    • bluehands77
      • Apr 2016
      • 8
      Here are some photos if it helps at all.
      The part number on my zsus is LG ZSUS EBR55360601 (which maybe is unfortunate bc it seems to be a more difficult board to find).
      • bluehands77
        • Apr 2016
        • 8
        And the rest of the boards...
        And one picture of what the symptom is.
        Thanks!!!!!
        • comptek
          • Aug 2013
          • 606
          looks like its the zsus is it slow at refreshing ?
          do you have a multimeter ?
          • bluehands77
            • Apr 2016
            • 8
            As I said, I'm a barbarian. I don't have a clue what I'm looking at.
            I don't have a multimeter but maybe I can get my hands on one if it's absolutely necessary for narrowing down the problem.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Z sus failure here, common issue on them boards I will link the repair kit which has the part numbers of parts commonly prone to failing so you can check them.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Link to repair kit:
                http://www.amazon.co.uk/LG-50PS3000-.../dp/B00H98102S
                • bluehands77
                  • Apr 2016
                  • 8
                  Thanks for the help Reecey,
                  I saw this repair kit locally on eBay as well
                  http://www.ebay.com/itm/LG-EBR553606...cAAOSwyQtVjNle
                  But I've no repair experience. I was under the impression these kits require soldering.
                  My thinking was towards getting a replacement board and switching them out. Seems like something I could handle myself.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    They do require soldering and on that type of board it is a lot of work and is hard to do. Probably best if your not good at soldering to get a replacement.
                    • bluehands77
                      • Apr 2016
                      • 8
                      Right. Ok, thanks.
                      Can anyone in the U.S. recommend a reliable source for a refurb? I see a few of them on eBay ranging from $55-80 but I guess I have no idea what kind of condition the parts will be in. ShopJimmy.com's out of stock. Not really sure where else to look.
                      • bluehands77
                        • Apr 2016
                        • 8
                        I realize the tv is "ancient" at this point but it seems like there were some recent inquiries for problems so I just wanted to point out that I bought a refurb and installed it. The issue is now resolved and everything is working fine. Hope this helps someone in the future.
                        The board part I had to get was the more difficult/expensive of 3 possibles that would have come from the manufacturer on this tv (I don't know if they're interchangeable). There were not many out there to choose from. Where the few I could find on eBay where around $60 or more, I was able to get a replacement thru a site called myshoptvs.com. It was $40 plus 25% off as a first-time customer and free shipping. Got here in 3 days, installed in 10 minutes and everything's hunky-dory.
                        • YellowJacket
                          Asus VX238H - pink area over picture
                          by YellowJacket
                          Hi friends,
                          I got this monitor, which works perfectly fine, except there is pink discoloration over right side of the screen ( picture1 ). When I disconnect LVDS cable, there is no sign of pink color, so its not backlight issue ( picture2 ). I took a closer picture of the upper right corner, you can see even some kind of pixel defects. Its only on that pink area ( picture3 ).
                          I believe, there is some problem inside the panel, the question is, if it is fixable. I have never met this kind of issue, so I really appreciate little help from you guys. What I tried so far - interrupt...
                          08-17-2023, 11:45 PM
                        • Tr0ll
                          by Tr0ll
                          Original T-con:
                          First replacement T-con:
                          10-07-2023, 07:48 PM
                        • JJAAMM
                          by JJAAMM
                          Problem
                          07-06-2023, 06:01 AM
                          Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                          This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                          09-06-2024, 09:30 PM
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
