PN64D7000 SAMSUNG - how to remove y buffer from y main
  • retro12345
    • Mar 2016
    • 13
    Guys,
    How do you safely remove the y buffer from the y main board. For the life of me, I feel like I'm going to break the pins holding the boards together if I pull any harder. Thanks for the help,
    Retro
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: PN64D7000 SAMSUNG - how to remove y buffer from y main
    Inching them out carefully a bit at a time at each end of the circuit board should do it. Not that I've done it but it is probably tight because of the number of connectors its attached to.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      Have you undone the caught-es on the connectors. the little clips on both sides of the bottom connectors that lock the connectors in?
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Good point.
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
          09-07-2024, 05:50 AM
        • Asraf Atb
          by Asraf Atb
          01-27-2025, 05:02 PM
        • JSin21
          Compatibility of main boards between different variations of samsung MU6100
          by JSin21
          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
          I have Samsung Smart TV UA65MU6100WXXY version DA01
          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
          11-27-2023, 04:54 AM
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
