Hello.. im planning to convert my MAGNAVOX 40ME313V/F7 which is rated at 120v.. to 220 volts.. I used to do it by replacing main capacitor.. but only on small appliance. I divided the UF by 2 and multiply the Voltage by 2.. it is in reference with its original main capacitor for 120 v use. Im a little bit hesitant because i have'nt tried that on big appliance. Please help me what to do.. my country is philippines 220 volts.
MAGNAVOX 40ME313V/F7 conversion to 220 volts
by u666saLaptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
Platform: ipa32 la-m024p rev 1b
Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
I found a short on the other side:
...Today, 05:03 PM -
by supermattchHi everyone.
I am diagnosing my personal laptop, because it wont power on and no leds light up.
At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.09-23-2025, 12:13 PM -
by MisterAILHi everyone,
Brought a non functionnal PS5. Apparently only a bad PSU...
No beep, nothing.
After some tests i found this :
- PSU is fine (12 volts stable)
- 12 volts line is shorted
- DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
- By the way, nothing change. No signal, no power, no beep.
Mesuring all rails with my workbench psu (12 volts input)
- 0.00 amp drawing
- 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...5 Photos -
by McfeetroyGood day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
by tonybig10Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...-
Channel: Schematics and Boardviews
03-07-2025, 01:03 PM -
- Loading...
