Technika 46-270 Solarized Image
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Hello All,
    I purchased this set at a reasonable price with a fault description that it was not powering up.
    Prior to replacing the main AV board, I froze U10 as suggested in several posts, however this failed to bring the set out of standby.
    A replacement main AV board (T.MSD306.68A 12023) arrived today which I fitted.
    Now I appear to have a very solarized image. Wouldn’t have thought that this was the problem prior to the mainboard going down, although possible.
    I believe that the solarisation may be due to not matching the mainboard to the LCD panel which is a Samsung LTA460HM03.
    Is this adjustable in the Service Menu and does anyone know the entry code. I don’t have the original remote and I am currently using a “Total Control” 4 in 1 remote.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Technika 46-270 Solarized Image
    That board is set to a 40" so it wont work with that screen. You need the board with the exact firmware flash for that screen.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Hello ReeceyBurger123,
      The board was advertised as being removed from a Technicka 46-270 so it would be disappointing to hear that it is not from that size set.
      Can I ask how you could be certain that the mainboard is suitable for the 46" panel and would a new U10 from Ohms Suppliers do the trick?
      Thanks for your reply.
      • vinceroger69
        • Mar 2012
        • 6714
        If you still have the old mainboard maybe try a replacement pre programmed u10 chip maybe send ohms supplies a email and see what they say.
        edit you beat me too it whilst i was typing.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Hello Vinceroger69,
          I have removed U10 from the old board but I don't know if that was the problem on the original board since the forum says that it gets corrupted and secondly if it is good could it be substituted in place of U10 on the replacement board and work the 46" panel.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Ohm Supplies do a replacement chip so if swapping my original over to the new board does not work I can order one from them. Annoying since it pushes up the repair price.
            E2P174 TECHNIKA LCD46-270 W46/57G-GB-3B-FTCU-UK COMPATIBLE EEPROM U10 T.MSD306.68A
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Have you had a look on their site ? Also it might have come from that model but these do use a variation of screens. Google says that the board and panel number you listed is for a 40" though. You need to get the firmware or board for that exact screen buddy.
              • vinceroger69
                • Mar 2012
                • 6714
                yes its looks the correct one even fully matches the panel number used
                http://www.ohmsupplies.co.uk/epages/...roducts/E2P174
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  The panel number given Samsung LTA460HM03 is on the back of the panel and is without doubt a 46" panel.
                  And thanks Vincerogers for the confirmation of the EEprom from Ohms Suppliers.
                  I think the old U10 is probably OK because when I was 'scoping the Clock Input on the old board there were no clock pulses to be seen which are needed to clock data in and out of the chip, so fingers crossed.
                  • Diah
                    • Feb 2013
                    • 6614
                    go in service menu and check the V-COM its same board but for different size of panel.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Hello Diah
                      I only have a substitute remote control at the moment and I don't know the service menu code.
                      • Diah
                        • Feb 2013
                        • 6614
                        try to inter engineering menu with
                        menu > 4711 then wait 15 seconds
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Will try that in the morning.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Ohh my days, that wont work with these you need a laptop and a usb hook up to be able to get into the SM. Thought at your level of skill you would know that on these TMS boards.
                            • Diah
                              • Feb 2013
                              • 6614
                              if you know that, you should write before my comment other wise i too it as.... wait and both we will learn, if my profile skills etch yours back. i can change it to zero to let you rest from Self torture.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                • martino
                                  Not so "senior"
                                  • Aug 2013
                                  • 997
                                  • canada
                                  Hey Diah,........Why don't you fuck off already.
                                  Proud owner of dozens of broken TV's and many,many,many boards.
                                  Our website and passion:http://hollenhundshepherds.com/
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Hello All,
                                    I replace the U10 IC on the replacement board with the one from the original board and the set is up and running.
                                    Many thanks to all who contributed.
                                    Edit
                                    If anyone has the ability to read U10 and make it available then I'm happy to send it to them.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Awesome
                                        Thanks for the follow-up, and reece, you have done it again.
                                        Too bad the board seller did not provide the information of the board as to where it comes from.
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • reach7458
                                          philips 37pf8404 solarized image (changed as15f already)
                                          by reach7458
                                          I got here an philips 37pf8404 with a solarized image. image one
                                          First guess its a bad as15f. so I replaced it with another. Same issues
                                          So I replaced it again with a rm5101. Same issues
                                          Problem is that is projecting a solarized image irregularly. When I pull the hdmi cable and put it back all is okay for a undetermined time. It also helps if I change the input from one hdmi port and back.
                                          One thing thats weird and I don't remember if it was the case with the previous tvs I repaired.
                                          When the image is solarized it doesn't affect...
                                          08-03-2020, 08:27 AM
                                          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 10:56 AM
