Pioneer PDP-LX508D Won't turn on, 3 flashes from PSU
+ More Options
Posts
  • niblettr
    • Jun 2015
    • 98
    Re: Pioneer PDP-LX508D Won't turn on, 3 flashes from PSU
    Nope, can't find it..
    • niblettr
      • Jun 2015
      • 98
      OK, found an OC 0.1ohm resistor. So replaced that and Fets with temporary equivalent.
      Vsus now powers up to the correct voltage but have since discovered there is a short on the ysus board.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ahh dam, maybe the Ydrive killed the Vsus supply. What devices have you found blown ?
        • niblettr
          • Jun 2015
          • 98
          3x FKP300A fets.
          Ybuffer seems to be OK but will double check when I've figured what's what on that PCB and the busbar.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ok good, in all honesty might be best to just change the Ydrive for the sake of the Ybuffer as the buffer is bonded to the panel and replacing the Ics will be very hard with that set up.
            • niblettr
              • Jun 2015
              • 98
              Thanks, I'm quite comfortable with surface mount rework.
              Where would be the best place to purchase said ydrive board?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                You can get them off ebay for cheap buddy
                • niblettr
                  • Jun 2015
                  • 98
                  Had a look, couldn't find any..
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Any luck ?
                    • niblettr
                      • Jun 2015
                      • 98
                      Not yet. Power supply is fully repaired and outputting the correct voltages on power up.
                      The new fets have not arrived yet.
                      There are 8x FKP300A fets that feed the scan pcb. 3 were fault so I removed those. Then, I swapped the remaining working ones so that I have 4 in a row on the the bottom to drive the bottom half of the panel.
                      On powerup I get 3 flashes from the red led. I suspect (HOPE) that it detects a SCAN fault because the top half fets are open circuit (removed as they are faulty)
                      On repairing cheaper tvs, i was always able to drive either top or bottom half of the screen without the tv tripping.
                      Just got to wait for the replacement fets to arrive.
                      On another note, I would have rather replaced the pcb as you suggested but can't find any for sale..
                      • niblettr
                        • Jun 2015
                        • 98
                        Fets arrive and installed.
                        TV powers up for 1/2 a second and display stuff in the top right corner then powers down and red led blinks 8 time.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #32
                          Ohh dear that means there is a fault with the Y address Pcb aka Y buffer. Do any of the Ic's look physically blown apart ? Replacing them wont be easy as the buffers are bonded to the screen.
                          • niblettr
                            • Jun 2015
                            • 98
                            No shorts on the y buffer ICs.
                            However, there are 4 pcbs along the bottom and 4 along the top of the display with 8 way wired connectors going to each of them. All the voltages are there except the 5 volts on any of the boards.... the y main feeds the left 4 (2 top 2 bottom) and the z feeds the right 4 so there must be a common signal that kept the 5v shut off as all the voltages going in to the ymain and z sus are good.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #34
                              Ok, possibly just a blown fuse some where have you checked the Smd fuses ?
                              • niblettr
                                • Jun 2015
                                • 98
                                cant find any blown fuses. Will look later on the bottom of the t-con when i get a bit deeper.
                                I made a bit of an assumption about the 5v feed to the 8 pcbs. Only on the bottom of the zsus does it say 5v which feeds the bottom 2 right pcbs. weird thing is, that 5v feeds (which always measures 0) are not commoned with any of the other assumed 5volts to the other 6 pcbs including the 2 bottom right pcbs. Its almost as if the label is wrong..
                                i.e the 2 bottom connects have the same labels which are identical and buzz out 1-1 except the 5v pin. Maybe they meant that pin is an address control line hence unique...
                                • niblettr
                                  • Jun 2015
                                  • 98
                                  Incidentally, the T-con does 8 flashes aswell (probably just mirrored onto the front red led. Strange I get a picture every time on power on for a split second.
                                  • niblettr
                                    • Jun 2015
                                    • 98
                                    OK, forget what I said about the 5V silkscreen. I was right, its wrong! The repair manual says it is NC (strange they put the bloody wire in in all 8 connector looms as well!!! Grrrr)
                                    So, fuses or buffer ICs. Question, would the whole panel light up if any of the buffer ICs are blown?
                                    Oh, I've re-seated all the flexis as well.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #38
                                      It would light up but have distortion then shut down. Did you say you get an image ?
                                      • niblettr
                                        • Jun 2015
                                        • 98
                                        Yes, I get the channel number etc in top right corner of screen etc
                                        • niblettr
                                          • Jun 2015
                                          • 98
                                          going the bin!
                                          • odie34
                                            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                            by odie34
                                            I am a hobbyist (not a professional) so please be gentle...
                                            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                            02-18-2024, 09:11 AM
                                          • matpod16
                                            Pioneer VSX-D1011 - turn on problem
                                            by matpod16
                                            Hi all! I have a problem with Pioneer VSX-D1011 – it don't turn on when the amplifier is disconnected from the socket for a few minutes. Standby LED doesn't light up. I'm a beginner in electronics, so I'm not very good at reading schematics. I tried to find the visual damages of components but I didn't see anything wrong. All of the fuses are ok, both of the switches the same. Have you any idea where should I start looking for? Once on every 100 tries I am able to turn it on, but what can it depend on?
                                            09-07-2023, 01:43 PM
                                          • Egidio85
                                            Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                            by Egidio85
                                            Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                            the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                            the fan does not start.
                                            I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                            any advice on what to check?
                                            06-10-2025, 05:00 AM
                                          • Noah Glasse
                                            LG 50PK590 - three clicks and steady red light, won't turn on.
                                            by Noah Glasse
                                            I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                                            I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                                            02-24-2025, 07:23 AM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
