No standby light. When testing voltages I find that the power supply puts out a good 5v when the logic board is disconnected. When it's reconnected the voltage drops to 2.7v. Would somebody please send me in the right direction to determine what may causing the voltage drop. Thanks again for your help.
Vizio E421VA No picture
Re: Vizio E421VA No picture
Disconnect the power supply from the main board and power up. Hopefully the +5V will come up as you indicate in your initial post. If it does and while still disconnected from the main board use a 1K resistor from +5V to PS ON and then measure the 12, 24V supplies.Last edited by dick_barton; 03-20-2016, 10:14 AM.Willing to help but I'm no expert.Comment
What voltage is on PS On before you connect +5V to it?Willing to help but I'm no expert.Comment
I did mean the PS_ON Pin. So it's 0v before you connect the 5V with 1K resistor which is fine. Try a 470 Ohm resistor or there about and see if that makes any difference.
When disconnected as described above if neither the 12V & 24V come up then you appear to have a power supply fault.Willing to help but I'm no expert.Comment
Look on the main board for IC regulators. The chances are that one of them has failed. Perhaps you could post a sharp image of the main board so we can see the components.Willing to help but I'm no expert.Comment
What's the number on top starting 715G-xxxxx
Any of the 3 pin devices marked as UxxLast edited by dick_barton; 03-20-2016, 11:13 AM.Willing to help but I'm no expert.Comment
I cannot make out the components on the picture but can see what appears to be two of the larger regulators as marked on the photo. There may be some 1117 regulators or similar which are also on the board that would need to be checked. Any capacitors with swollen top caps?Willing to help but I'm no expert.Comment
There's something pulling down the 5V supply and it could be one of the regulators because it's not quite a short circuit. As Diah suggests they probably obtain the 3.3V from the 5V via one of the regulators.Willing to help but I'm no expert.Comment
I have remove all the cables from the main board and the voltage is still at 2.7v. Something on the main board is pulling down the voltage. At this point I will try to find a replacement board. I appreciate your time and effort going thru this with me. Sometimes they show up on Ebay and shopjimmy does have them. Do you know of other places I get a used one?
Thank you again.Last edited by rod30; 03-20-2016, 12:10 PM.Comment
Shopjimmy does appear to have the market in the US. I buy locally within the UK.
Good luckWilling to help but I'm no expert.Comment
by gavricHello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
When tv powers on vizio V logo shows nice on whole screen. picture 1
When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
When i start youtube picture shows on left side fine, right is all scrambled. pic 2
When i click video to start playing picture goes black(like when you change... -
by ggil44Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
by maricmHI all,
hope someone point to the possible issue before I start buying replacement parts.
Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
Backlight stays on all the time,
Sound works fine.
screen keeps changing form black to full picture in about 1sec intervals.
Picture looks fine with no visible artifacts.
I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
Disconnecting left and right ribbons on... -
by csmithI replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
issue. Set will power up with remote but not power off.... -
I have a VIZIO E70-E3.
Symptoms: Black screen, no picture, but LED backlights are working.
I probed the power board and voltages are as listed on the board.
Main board appears fine, too.
I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
There are two separate ribbon cables feeding the LCD.
If both are connected, the screen is black.
If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and... - Loading...
