Panasonic TC-P58VT25 - "10 Blinks" problem
  • checkport88
    • Mar 2016
    • 22
    I got a Panasonic Plasma TC-P58VT25 for free, but it is displaying the "10 blink" error, and I would love to diagnose and repair this TV.
    I have seen the variety of things that might be wrong according to the service manual and from what others posted online. But I haven't been able to figure out the problem yet.
    The SS board green LED is lit when I power the TV, but the LED on the SC board doesn't light up.
    I have a bit of electronic experience, but not doing repairs on the component level, but I would love to learn. I have a DMM and soldering gear ready to go.
    If anybody has any ideas of what the problem(s) might be, or if this has already been dealt with in another thread please let me know.
  • Diah
    • Feb 2013
    • 6364
    Re: Panasonic TC-P58VT25 - "10 Blinks" problem
    10 blinking in general at Panasonic are back light shorting or bad panel. bad caps
    disassemble it and inspect it.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      It's a plasma. No back light.
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        Sorry,but that doesn't even begin to make sense. If you don't know,don't reply.
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
        • checkport88
          • Mar 2016
          • 22
          I had the SC board out last night and everything looked okay physically, although I'm not completely sure what to look for. I was wondering if it wasn't getting Vsus power at SC2.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Check Q661 on SC for short.
            If it is, there'll be a whole lot more shorted parts on the SC board too....
            TELEFIX
            • Diah
              • Feb 2013
              • 6364
              then let me know if you do know... i wrote in general. and this true..
              • checkport88
                • Mar 2016
                • 22
                Do I need to de-solder Q661 to check for a short? I did try checking it last night, but I wasn't really sure if I was doing it properly.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  With Panasonic--The model number gives it away.
                  tc 'P' 58xx-xx etc.
                  Where P hints to Plasma....
                  Samsung and LG are much the same, but the other way round, having 'L' in the number....
                  TELEFIX
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    Nah--Dont need to. If short--It'll be Dead-short Emitter-Collector, less than an ohm
                    TELEFIX
                    • martino
                      Not so "senior"
                      • Aug 2013
                      • 997
                      • canada
                      It's simple,you saying "10 blinking in general at Panasonic are back light shorting or bad panel. bad caps" might make the owner think "oh,bad panel,better just throw it away".
                      You can't just throw a opinion out based on nothing! Like I said,if you don't know,then don't say anything,sit back and read and learn.
                      Do I know? Yes I do. But there is TW2005,Alastair,Budm etc that know WAY more then me so I don't say anything.
                      I did however check if I have a sc board here as I live in the same province and I checked my notes to see if I repaired a TNPA5175 before.
                      Sry to interrupt the matter at hand,last thing I had to say about it.
                      • checkport88
                        • Mar 2016
                        • 22
                        Thanks, I'll check again later. I should be using the diode setting? or resistance?
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Resistance tests are what I use for first run diagnostics on semi-conductors like these IGBT's, usually the 200 ohm range on meter.
                          More exacting testing comes after. A Short will show up on resistance And on diode--But a good working diode junction will Not show up on Resistance test-IF its not shorted/faulty/leaky.
                          Diode test usually supplies from meter around 5V. This is enough to 'Forward-Bias' --Turn-on-- a diode--so current flows.
                          Diodes normally need around 0.7V to forward-bias, although some specials (shottky diodes) can bias at around 0.3V.
                          Resistance tests from meters usually supply 0.2V so don't turn diodes/transistors/semis on, but find proper shorts or test resistors etc--Its almost like testing parts on the circuit and ignoring all the semis on the board...
                          TELEFIX
                          • checkport88
                            • Mar 2016
                            • 22
                            I re-checked Q661 and confirmed that it is shorted. I checked the other transistors and diodes, it looks like there are several that are shorted.
                            I probed from the underside of the board on the solder points because some of the legs were difficult to access. Would this yield the same resistance values?
                            What direction do I need to take now? Probably check capacitors, resistors, any thing else? Replace anything that is shorted. Should I be worried about the SD and SU boards?
                            • gdawg
                              • Sep 2012
                              • 170
                              I would recommend searching on Google for Panasonic tc-p58vt25 technical guide and download it.
                              There is all the info in the technical guide you need to trouble shoot. This is a very complex board and can be hard to repair unless you have a lot of patience. There are kits available that include the most common failed part but not always all of them.
                              Very important to check your buffers for shorts, cause a shorted buffer will take out all the work you did on the SC board.
                              Common that the SU fails.
                              Unless you are really good at soldering very small components, you might look into a replacement board or a repair. You dont want to attempt a repair and then send it out for repair, cause most repair shops wont touch it if it has been attempted to repair.
                              • checkport88
                                • Mar 2016
                                • 22
                                Thanks for the advice. I have the technical guide and the service manual, which I will have to read through. I think that buying new boards is not really an option judging by the price and availability of them. I've been looking for something to solder anyways so I figured this would be as good as any.
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  You also need to check the buffer boards for shorts.
                                  Check this vid :
                                  https://www.youtube.com/watch?v=51SZsfH60EY
                                  If they are ok then your SC board is probably the only board that is bad.
                                  Well , you got the TV for free , with a new SC board you got a nice tv for little money!
                                  • gdawg
                                    • Sep 2012
                                    • 170
                                    Great, -- its challenging and you will get a lot of practice soldering. Be patient, don't hurry through and it is really cool to fix the board. There is plenty of help on the forum-
                                    • checkport88
                                      • Mar 2016
                                      • 22
                                      Awesome! I guess I know what I have to do. Thanks everybody for the help.
                                      • gdawg
                                        • Sep 2012
                                        • 170
                                        You can probably put the board number in the search section of the forum and there are some real experts that have repaired that board. If you read thru the posts you will pick up some real valuable info on the repair. Good luck and you might report your progress as you go along.
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          11-20-2024, 08:52 PM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
                                        • hugocarmo
                                          Panasonic TX-24A1UN CRT Sound and Input problem.
                                          by hugocarmo
                                          Hi.
                                          I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
                                          It is imaculate inside, almost no dust or debris inside.
                                          The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                                          So I started to look for a service manual, I found one, and started from the beginning.
                                          Most of the times the caps are the problem so I orderer all the caps for all boards,...
                                          04-26-2025, 07:45 PM
                                        • renech
                                          panasonic TH-42PC77U plasma television half screen problem
                                          by renech
                                          hello,
                                          I hope someone on this forum can assist me.
                                          I have a panasonic TH-42PC77U plasma television.
                                          the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                                          i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                                          I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                                          I have read some posts that suggest the problem is related to the boards on the left...
                                          12-12-2022, 06:53 PM
                                        • Vebririon
                                          panasonic TX-P50V10E 6 blink led problem
                                          by Vebririon
                                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                          05-17-2025, 10:16 AM
