toshiba 40L1333b 17MB95s-1
  • tn245
    • Oct 2013
    • 530
    Re: toshiba 40L1333b 17MB95s-1
    russellhearn69, that's great you got it going. Can you point us to where you found the software in the end? Did it come from the toshiba website or did you find it somewhere else? Some of us are collecting the software so always useful to find new sources.
    Also do let us know if the fix holds.
    • russellhearn69
      • Mar 2016
      • 16
      • Northern Ireland
      Originally posted by ReeceyBurger123
      Awesome One thing I want you to do, if it fails again in a few days with the same symptoms/fault of flashing Led let us know.
      I sure will, I wouldn't want any other member to go through what i just went through, I was up all night as it was doing my head in.
      • russellhearn69
        • Mar 2016
        • 16
        • Northern Ireland
        This is where i eventually forund the software.
        It was on a website called http://www.tv.quuq.org/ and the forum post was http://www.tv.quuq.org/forum/index.php?topic=9810.0 and it was on reply #7
        http://www.mediafire.com/download/hd...8_27092518.zip
        Hope this helps
        • tn245
          • Oct 2013
          • 530
          Hope this helps
          Thanks!
          • steviewonder
            • Dec 2013
            • 183
            • england
            Someone beat me to it!
            I didn't know I could upload the file here,I was under the impression only links worked!.
            A curious problem can occur I have noticed after flashing the firmware-that's a random blinking problem,as if the firmware is corrupt again...not got to the bottom of that one yet..
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              Look what I said further up, I asked if it fails again in a few days, I have had this issue so many fucking times. It works for a day or two then the firmware fails again however after reflashing it again after it broke down it will work for a good while. Im unsure why maybe Bud or Tom has an idea.
              • vinceroger69
                • Mar 2012
                • 6714
                #27
                Could it be the actual eeprom chip is faulty if your using the old one that is.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #28
                  Im starting to think that's the case for these Mb95 board, the SPI IC needs removing, and a new one needs to be completely reflashed and installed for these boards. The 17mb82 normally work fine and don't need a new IC from the ones I have done.
                  • Diah
                    • Feb 2013
                    • 6435
                    there are other way with Toshiba to clean install firmware.
                    1-rename mb90_en.bin to mb90_WOAP.bin and let it alone on root USB and start it with Tv for 2 minute. this WOAP are clean eprom and keep its partion. ( TV WILL NOT show any on screen, it may only TOSHIBA Logo if its there at firmware.
                    2- rename back mb90_WOAP.bin to mb90_en.bin and put the mboot.bin with and Flash them.
                    this method can be used also for the last generation of Toshiba 3D TV.
                    • tn245
                      • Oct 2013
                      • 530
                      Do you mean the SPI or the NAND needs replacing? SPI has the mboot and NAND the main software. I thought it was mainly the NAND that was corrupting?
                      • russellhearn69
                        • Mar 2016
                        • 16
                        • Northern Ireland
                        #31
                        Just a little update......
                        Well i thought i was doing fine with flashing the firmware as the tv work flawlessly untill the other night when it decided to bugger up again but after flashing the firmware again it's working again, so it looks like there is something else that is causing the firmware to fail
                        • sordids999
                          • May 2013
                          • 2161
                          #32
                          Worth a try
                          A common issue,as many will know,is firmware corruption on these,and it's variants.
                          After flashing,you may find that when cold,it will revert to the dreaded blinking light scenario.Many have suggested it's a worn-out flash chip-This is not the case.Its caused by a Multilayer ceramic cap,fitted above C137,directly above the letter C.simply remove it.
                          Problem solved
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #33
                            Really your joking right ?
                            • sordids999
                              • May 2013
                              • 2161
                              #34
                              lol well it was posted on badcaps the other day referance another vestel fix so.......
                              just an idea mate
                              • sordids999
                                • May 2013
                                • 2161
                                #35
                                And if i was joking ill be saying april fools by now
                                https://www.badcaps.net/forum/showth...highlight=c137
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #36
                                  Lol might give it a shot next time I get one of these, it wont be long either if it works that would be awesome.
                                  • thirstygums
                                    • Oct 2020
                                    #37
                                    thanks for the firmware- any way to get it working on 40L1333DB
                                      09-06-2024, 05:27 AM
                                      09-06-2024, 05:59 AM
                                      09-06-2024, 05:33 AM
