Screen turns off when attempting to use VGA input on Samsung LNT4042HX LCD
  • SurrealMustard
    • Jan 2015
    • 486
    • The United States of America
    Got another stumper for the community. This one is right up there with some of the strangest problems I've ever seen on anything:
    Basically, this Samsung LCD television works fine, but when tuned to the VGA input, it will blank the screen and turn off the backlight and slowly blink the power light until the video source is turned off or the cable is disconnected, at which point the screen will turn back on and display the usual "check connection" message. This has been an issue for years, but we just stopped using the VGA port when it originally cropped up because the issue is not present on any other input. When it originally started, it happened suddenly and abruptly and without explanation or provocation.
    Originally, I thought it was perhaps some kind of settings issue, so I reset the television and even upgraded the firmware (successfully), but the problem on the VGA port still persists. Is there any known fix for this, or are we just going to have to stick with HDMi and component if we don't want to replace the mainboard?
  • sordids999
    • May 2013
    • 2157
    • uk
    Re: Screen turns off when attempting to use VGA input on Samsung LNT4042HX LCD
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      VGA set to too high a resolution for the set..
      TELEFIX
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        SurrealMustard,
        It would be interesting to know if Alastair E hit your problem smack on the head for future reference
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          I ran into this issue with an old Plasma Samsung set--It was a 480p/EDTV set, on anything higher than equiv 720p set would shut down...
          Just a thought...
          TELEFIX
          • SurrealMustard
            • Jan 2015
            • 486
            additional details
            That's kind of difficult because this one is still on the wall, hooked up, and in circulation. I'll see if I can find any pictures on the web and if not, we will explore the logistics of taking it down to photograph.
            Originally posted by dick_barton
            SurrealMustard,
            Just a thought...
            Negatory. It does this at all supported resolutions. The only way to bypass the problem is to unplug the cable.
            • budwich
              • Jul 2015
              • 3097
              Does your problem exist whether your vga cable is tereminated or not... ie. with something / computer plugged in versus just the cable only. What kind of vga cable have you been using.... ie. full 15 pin or an "abreviated" one... note just because there are 15 pins in the connector doesn't mean that all pins are connected.
              • SurrealMustard
                • Jan 2015
                • 486
                supplementary details
                You mean connected, but with the computer not outputting video to it? I have not tried that yet, but will do so the next time I get a chance and report back the findings.
                Originally (years ago when the problem first cropped up) we were using a VGA extension cable, which I know for a fact did not have any of the data pins connected. I don't think this has much bearing though because it was working fine with that extension one day (and many days before that) and stopped the next. I'll try to track down a "non-abbreviated" cable and see if it makes any difference though.
                • budwich
                  • Jul 2015
                  • 3097
                  Of course, you haven't indicated what is on the other end of the vga cable but you have now indicated that it worked and then stopped... hmmm. Did the "other end" change? What devices have you tried?
                  • SurrealMustard
                    • Jan 2015
                    • 486
                    interesting VGA finds
                    At this point, one standard desktop video card and one laptop.
                    Does your problem exist whether your vga cable is tereminated or not.[?]
                    Got around to testing this again today. Interestingly enough, if a computer is off (but still connected), the television will do the same thing. Very fascinating.
                    What kind of vga cable have you been using[?]
                    Upon testing it with another monitor, I have confirmed that the cable I am using to test is indeed a fully-featured one, so now we know that the issue exists with both types (fully featured or video-only).
                    • budwich
                      • Jul 2015
                      • 3097
                      Not sure what you mean by "full featured"... you determined this by doing a continuity test on the cable?
                      It would appear from the "computer off" test that your issue is indeed more with the TV set / connector than the computer end.... hence the previous question.
                      • Diah
                        • Feb 2013
                        • 6399
                        Re: interesting VGA finds
                        Originally posted by SurrealMustard
                        its common fault by this model of Samsung, No picture or turn off at Analog PC signal ..
                        it caused it 2 reasons
                        1- the jack CN1000 the black color on the left side of PC socket input on the main board.
                        2- the Main IC400, failed at switching to Analog PC Signal.
                        no 1 are the most insert sound source in it from PC and try
                        • budwich
                          • Jul 2015
                          • 3097
                          my limited findings with a samsung is that grounds play an important role. I would check the cables being used first before going into the "bowels" of the set especially if you need to demount it.
                          • SurrealMustard
                            • Jan 2015
                            • 486
                            response to findings
                            By "fully featured", I mean that it has more than just the video pins connected because it does transmit resolution support data from the connected display to the computer, unlike the primitive cables which do not do this.
                            Interesting that you mention it being a common fault. I ran some web searches and found hardly any reference to the issue. Going back to the diagnosis though, which one is the CN1000 jack? And what did you mean by "no 1 are the most insert sound source in it from PC and try"?
                            That's what I was thinking too. Are Samsungs more sensitive to the kind of VGA cable that is used? Or do they become less keen on lower quality cabling over time (as seems to be the case here)? At any rate, I've got a couple other spare cables hanging around, so I'll give them a try when I get a chance next.
                            • Diah
                              • Feb 2013
                              • 6399
                              if you were searching the web on the service manual of yours TV was better than searching on the same mentioned fault..... funny......this fault also described at service manual of this model.
                              any way.. on the left side of pc SOCKET on the TV a audio PC in, use only IN with audio signal and switch tv to pc source. you will know if it gone off or not.
                              tipps, of sure you have never used this pc audio input. suggest to plug the jack first in out for several time then test.
                                How did we go from ' Screen turns off when attempting to use VGA input on Samsung LNT4042HX LCD' to PC audio input? I surely like to see the service manual that describes this fault, it will save us lots of time.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  Re: response to findings
                                  Like any "complex" comms standards, vga can be implemented is almost any form by a given manufacturer AND the same can be said of the cables... :-)
                                  Like hdmi, various scenarios of vga with cables, equipment, deployment layout can cause lots of headaches.
                                  Changing cables "blindly" may or may not help... you need to actually do some testing of a given cable to ensure you understand what is connecting where paying particular attention to grounding (based on my "experience"). In vga, there are lots... :-)
                                  • SurrealMustard
                                    • Jan 2015
                                    • 486
                                    Samsung VGA
                                    That's what I was thinking too. I think what he may have been getting at was to see if there is still sound when the television turns off the screen during those times when the VGA cable is plugged in.
                                    So that's a "yes" to my question about the Samsung perhaps getting kind of cranky about the VGA cables that it would like to accept in its old age?
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      not sure you can blame samsung. Cable "characteristics" can change just from plugging and unplugging... either as a result of poor wiring, corrosion, etc... That's why you need to look at the cables to ensure they are doing what they are "designed" for.
                                      • SurrealMustard
                                        • Jan 2015
                                        • 486
                                        So... yes?
                                        Physical wear probably would not have been an issue because the VGA cable we had in there before had been connected to the same computer for two years completely undisturbed before it abruptly stopped. As for the possibility of corrosion, a mysterious case of it would've had to have come over all our other cables around the same time too because each and every one of them works fine with every other monitor and television that I have access to except for this Samsung.
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                          by JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                          Please help. Thanks in advance!
                                          08-12-2025, 11:45 AM
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
