Seiki Se65gy25 grey screen
  • freediver
    • Mar 2016
    I have done a ton of research on Seiki repair and have had no luck finding anything. Unfortunately Sieki has some of the worst customer service I have ever experienced. It started one morning when I turned the TV on I saw a grey screen slowly appear from the bottom up in a hazy crawling motion. It still has sound. I replaced the TCON board with no luck, actually might have made it worse, so I put the original back in and ordered a main board. The new main board fixed the issue for about two weeks. Now I see the same crawling grey screen every time upon start up in the morning. Occasionally a power reset will get it working but I usually have to let it run for ten minutes and then do a power reset. Could be a heat related connection issue?
    The most recent issue has been an error message when trying to play a playstation3 through the HDMI which reads "unsupported data" with blue screen behind it. Yet at the same time I can switch the input to the cable box and that will work, also an HDMI port. The same thing occurs where I have to reset TV or let it run a while to get the error message to stop. If you have any suggestions please let me know. Thank You.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Seiki Se65gy25 grey screen
    Please could you post pictures of the circuit boards and back of the set with cover removed.
    Have you taken any voltage readings on the power supply board.
    Do any of the capacitors look as though the tops are bulging?
    • mohammedgladiator
      • Mar 2016
      • 17
      • palestine
      why grey screen what reason
        Also the screen shot of what you are seeing on the screen.
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • LEONARDO DE FREITAS
          Chinese multimedia crashes on the home screen, could someone help with the software or factory reset?
          by LEONARDO DE FREITAS
          Hello everyone, I have 2 multimedia systems with a 9-inch screen that turns on and only stays on the Android screen. It is very likely a software update. I have 2 software programs here but the multimedia system does not start the installation. Has anyone encountered this problem? I would be grateful if you could help.
          04-18-2025, 09:58 AM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
