Pelco 42 inch Monitor Shuts off .5 secs
  • neverexisted
    • Nov 2012
    • 76
    Hey guys hoping you can tell me where to start with this thing. I got a seemingly brand new pelco monitor 42 inch model PMCL542F.
    I visually checked the boards and all caps etc look fine no burnt spots or bulging that I can tell I've yet to do anything further because honestly I'm not sure where to start.
    The monitor/tv turns on for half a second shows logo and then turns off. It also makes what I could only describe as crickets/clicking noise when plugging it in after being unplugged for awhile.
    Also not sure if that is a inverted board on the far left or not.
    I am just hoping someone can tell me where to start. I.e. inverter, PSU, mainboard etc.
    I am attaching a video and some pictures below.
    https://www.youtube.com/watch?v=RIlixvsiKB4
    you can hear the crickets when I plug it in in the video.
    http://imgur.com/a/WC9lx
    there is a link to the hi res images
    Thanks guys hope you can help
    Got this from a local recycler hoping to bring it to life and make it my computer monitor.
    Cheers guys appreciate your time!
    Re: Pelco 42 inch Monitor Shuts off .5 secs
    Remove the two connectors for the Inverter board (the long board under the metal shield) and see if the clicking goes away.
    • neverexisted
      • Nov 2012
      • 76
      Unplugged and still same noise. Upon further inspection its definitely coming out of the main PSU. I can't be sure but putting me ear as close as I can without fear of getting bitten, it seems like its coming from those blue blocks. I guess they are "AC film capacitors"?
      Circled them here: http://s30.postimg.org/k45z8zd69/dnj7_Sz_Y.jpg
      Also circled the entire area where I know the noise is coming from.
      here is pics of the two of those blue capacitors: http://imgur.com/a/xghHz
      So am I wrong to assume that they stopped using CCFL backlights in these newer model displays? If that is indeed an inverted board.
        Those are X/Y safety caps Line noise filters.
        Did you do any DCV checking to see if the DCV on the cold side connectors have steady DCs?
        • neverexisted
          • Nov 2012
          • 76
          I did not and I only slightly understand what your talking about. But I do know how to read fairly well......
          • neverexisted
            • Nov 2012
            • 76
            You mean check the dc line out on the psu with a meter? By cold side do you mean the DC side of the PSU?
            • neverexisted
              • Nov 2012
              • 76
              So those basically clean the AC current before it gets converted by the transformers?
                There are three white connectors on the cold side of the power supply board, those wires for the connectors go the inverter board, the main board.
                The pins of the connectors are also labeled to tell you what they are.
                • neverexisted
                  • Nov 2012
                  • 76
                  Ok gonna check voltage on them now
                  • neverexisted
                    • Nov 2012
                    • 76
                    Showing 13.98v on the 12v pins, 4.98v on 5v standby. The inverter board doesn't show anything but this is with it powered off. Not sure if I should turn it on and try.
                      The switched 24V for running the inverter board will not be present until the power switch is activated and the monitor is fed with signal otherwise the monitor will go into standby by due to lack of video signal from PC.
                      • neverexisted
                        • Nov 2012
                        • 76
                        So where should I go from here. Its a 2500$ monitor. think I should swap the inverter.
                        What I mean by that is itd be worth it to swap some boards if i need to.
                          So you have the cable between the power supply and the inverter board connected back in place but and there is no 24V from the power supply board to feed the inverter board?
                          And without the Inverter cable connected you also do not have 24V at the power supply connector? If that is the case then you have power supply board problem. Inverter needs that 24VDC from the power supply.
                          • neverexisted
                            • Nov 2012
                            • 76
                            Should I test that with it powered off
                            • neverexisted
                              • Nov 2012
                              • 76
                              So leave it in standby and test for 24v on that pin?
                              • neverexisted
                                • Nov 2012
                                • 76
                                ok tested in standby and 28 volts on all pins leading to inverted board.
                                  So all the Voltages so far are steady then?
                                  You have indicated that it shutdown in half second do the power LED goes off or you see the image on the screen for half second and then the backlights shuts off but the power LED is still on, is that right. Or it is like as if someone turn off the power switch.
                                  I am trying to understand the shut off part.
                                  • neverexisted
                                    • Nov 2012
                                    • 76
                                    Voltage is all steady far as I can tell.
                                    Turns on half a second shows a clear image. Standby light goes from red to green. Green light stays on after it shuts off as if it were still powered on. No image when shinning a flashlight so I Dont think that it is a bad backlight.
                                      The monitor did not shutoff it is still power on with all the DCV present, only the backlights go out.
                                      So it can be either the Inverter board or lamps problem.
                                      Can you remove the metal shield so we can see what are on the inverter board.
                                      • neverexisted
                                        • Nov 2012
                                        • 76
                                        Wait so should I power it on then check the voltages again after the monitor shuts off?
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
                                          Wise Wing F199 19'' LCD monitor - recapped
                                          by momaka
                                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                          When I saw the Craigslist post, I wasn't...
                                          08-24-2020, 10:58 AM
                                        • sew333
                                          Pc shutdown, monitor flickered with no signal after 10 seconds
                                          by sew333
                                          My pc:
                                          10850K stock 4800mhz stock Kraken X73 good temps
                                          2x16 GB DDR4 GSKILL 3000mhz XMP
                                          Seasonic Tx-850 Ultra Titanium
                                          Gigabyte Rtx 3090 Gaming OC
                                          Aorus Z490 Pro Gaming
                                          1 TB SSD
                                          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                          Power...
                                          02-22-2022, 10:27 AM
                                          Lenovo ThinkPad X1 Yoga + T24i Monitor (61CEMAR2AU) Hybrid (2-in-1) X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Yoga + T24i Monitor (61CEMAR2AU) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + T24i Monitor (61CEMAR2AU) boardview and X1 Yoga + T24i Monitor (61CEMAR2AU) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 11:32 AM
