Sharp LC-32LE653U LED TV
+ More Options
Posts
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Hi Team. I have this Sharp LED TV that shows great picture and otherwise everything works well. However, my problem is that I cannot connect to Netflix or any of the other installed Apps like youtube etc. When the Netflix button on the remote control is depressed the screen shows 'connectin...Please wait'. Then after awhile it reads cannot connect check Modem, etc, The TV is connected to wireless WIFI and can connect the Browser, so I could search sites via Google, etc. Actually I am on the TV now connected to Badcaps Forum. What could be the probable fault?
    I have not opened it as yet and have never seen this problem before. Thanx for the help.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sharp LC-32LE653U LED TV
    I would say corrupt firmware buddy, have you factory reset it ?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Thanks for your quick response, my friend. Yes I did try a factory reset and same thing....I should tell you this set is just 3mths old could faulty line voltage cause this??
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        I dont think so, sounds like firmware too me I had a Vestel Smart Tv with bad firmware and it kept saying "connect wifi antenna" see what others think
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Sure thing there. I'll believe you are correct. I can't find any service info or firmware, too.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            No worries mate, finding the correct firmware is like trying to find a needle in a haystack
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              You bet. I'll probably take it back to the store where I purchased it and get them to look at it since it is still under warranty...It is ironic though that I could repair other people's TVs but can't repair my own....Ah well...Thanks for your valuable input, friend..Cheers.
              • budwich
                • Jul 2015
                • 3097
                I guess the one question would be, has it ever worked on your network? Potentially a setup issue maybe. I would give a try on someone elses network first if possible just to test a different network setup.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  No worries hope it goes well.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    I left the TV unplugged over night and decided to give it one more try before taking it in. Lo and behold it came up and everything was working. I turned it off waited a while and switched it on again and, yes it worked all right. Just thinking, could leaving unplugged for a few hours and then turning it on reset the system?...I hope so as then I wouldn't have to worry about it again. I unplugged it again last night and will try it again when I return home this evening.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Does anyone know how to get into the Service Mode?? Would rally appreciate if you can share with me, please.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Sorry didnt see reply, any luck ?
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          Thanks Reecy. What actually was the problem is that my Router was unable to handle the broadband. It worked well with the 720 but not so with the 1080. I replaced my old router with an upgraded one and that solved my problem entirely. Regards AFA
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Ahh lol, glad to hear its sorted
                            • KYBOSH
                              Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                              by KYBOSH
                              I picked this one up today.
                              Previous owner says no signs of life.
                              TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                              Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                              The TV model is QN65LS03BAFXZA - version: CB06
                              The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                              I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                              Will keep you all...
                              04-05-2025, 08:32 PM
                            • An-klamm
                              Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
                              by An-klamm
                              Hello!
                              I have a TV that I can't get any further with.
                              It is a Samsung UE 55HU8590 with one connect box.
                              When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
                              As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
                              Since the TV works without ocb, I assume that it can't be the PSU?!
                              I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
                              Is there...
                              12-04-2023, 01:35 AM
                            • AlexVG
                              SAMSUNG UE65HU8500 ONE CONNECT pinout connector request
                              by AlexVG
                              I came across with
                              SAMSUNG UE65HU8500
                              ONE CONNECT BN41-02135
                              Chassis GOLF_UHD_1MP_JACK
                              TV can not recognise ONE CONNECT box, so I need to know the pinout of the CN 3301 connector.
                              Moreover, on the main is written A5V. However, cable connected this pin to the GND.
                              Maybe somebody have an experience with the same issues?
                              I need your help.
                              Thank you....
                              06-08-2025, 06:49 AM
                            • sefoster
                              Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                              by sefoster
                              I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                              11-20-2022, 09:29 AM
                            • SONY_E-WASTER
                              Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                              by SONY_E-WASTER
                              Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                              The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                              then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                              does...
                              12-26-2021, 05:46 PM
