Hitachi 40L1333B
  • vasja113
    • Mar 2016
    • 7
    • 81354119992
    Hitachi 40L1333B
    Hi!
  • vasja113
    • Mar 2016
    • 7
    • 81354119992
    Re: Hitachi 40L1333B
    I have a problem with Hitachi 40L1333B. When you turn on the stand by me screen flashes and disappears both picture and back ligt. Power remained at 12 and 24, the indicator shows that the TV is turned on.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Well thats not a hitachi Tv for first thats a Toshiba but still both are Vestel junks. If you shine a torch on the Lcd do you have image under neath ?
      • vasja113
        • Mar 2016
        • 7
        • 81354119992
        Sorry,Toshiba!No, the image disappears!
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Ok, does the backlight stay on ?
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            He said that the backlight turns off also!
            Sounds like a bad power supply. Do you have pictures of the boards?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Ohh lol, but he also said 12v and 24v remain so chances of Psu are little. So does the sound go too when it goes off ? You also need to check the Led drive voltage too sounds like a backlight fault to me.
              • vasja113
                • Mar 2016
                • 7
                • 81354119992
                DIM line is 3.3V
                • vasja113
                  • Mar 2016
                  • 7
                  • 81354119992
                  LED checked, all 45 veseli.šodien even managed to turn 3 times, but quickly disappeared again, did not manage to properly measure the all suspicious spriegumus.Uz LED was 150V, all shone.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Can you please rephrase that lol ?
                    • Jaime Morillo
                      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                      by Jaime Morillo
                      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                      The TV was stuck on the logo and I couldn't access the update menu.
                      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                      The image result was good, but the image is inverted.
                      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                      08-18-2025, 11:38 AM
                    • massimomax
                      Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                      by massimomax
                      Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                      spero che qualcuno può averlo per riprogrammare eprom. grazie
                      Post in English !!!
                      I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                      02-28-2025, 07:27 AM
                    • dragometin
                      Hitachi 40HYC42
                      by dragometin
                      TV Model: Hitachi 40HYC42
                      Power Supply: 17IPS71
                      MainBoard: 17MB95M
                      Panel: VES400UNDS-2D-NO3
                      When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                      I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                      Is there any variants on 17IPS71 power supply's?
                      UART output pins 10 and 12 on scart connector:
                      Code:
                      12:24:04.595
                      08-08-2024, 05:53 AM
                    • sotodefonk
                      Help finding the correct model of a T-Con board on my Hitachi TV
                      by sotodefonk
                      Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                      I opened the tv to access the board and took the shared pictures of the T-Con board.
                      I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                      I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                      Inspecting...
                      06-28-2024, 04:39 PM
                    • dicky96
                      Hitachi V19B01922 Channel Tune problem
                      by dicky96
                      Hi Guys
                      I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                      He also has an LG TV, so three screens in the bar
                      I installed three Satlink ST-6503 DVB-T Modulators
                      This model https://www.aliexpress.com/item/32916553905.html
                      These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                      02-09-2023, 09:20 AM
