Panasonic TX-P46GT30B
  • crt man
    • Mar 2013
    • 106
    • England
    Hi all
    I have a 8 blink problem with the above set I have found
    a manual and the causes are.
    Driver SOS3 Checkpoint SS-board.
    (SS FPC DET)Checkpoint SS2-board
    (SS Energy Recovery Circuit) Check point SS PFC
    and SS2 PFC
    I am not sure where I should be looking,
    especially SS PFC and SS2 PFC.
    Any help would be greatly appreciated.
    Alan.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TX-P46GT30B
    providing the SC is connected then 8 blink should be SS. SS PFC and SS2 PFC are the flex cables to the panel.
    Maybe check Q102 on SS , RCJ330N25 on a hunch it may be shorted.
    • crt man
      • Mar 2013
      • 106
      • England
      Hi
      Q102 not shorted, I now have another SS board,
      as I thought original had been burning,and there
      was marks on the frame, but could not work out
      why as the screws were tight.
      Update now screen shows some life and Viera
      banner comes on then as fans start to run it
      shuts down with 8 blinks or sometimes LED
      will stay on green but screen goes off, the only thing on the
      SS2 board is a diode with two resistors.
      The diode measures good, unless it is breaking down
      when current is applied.
      Alan.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Mainboard can also cause 8-blink faults....
        TELEFIX
        • crt man
          • Mar 2013
          • 106
          • England
          Hi
          That's what I thought but this is not mentioned
          on the service manual,I hope to have a A
          board delivered today,so here's hoping.
          Alan
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            So did your mainboard fix the problem?
            • crt man
              • Mar 2013
              • 106
              • England
              Has not arrived yet.(sigh)
              Alan.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Ok im curious. Does your set also show some vertical lines/bars + distorted picture? Like a scart cable thats not seated correctly? It stays on for 1 or 2 seconds and then it shuts down.
                Can you remove the small ribbon cable going from mainboard to the SS board and leave all other cables as is. Does the tv stay on?
                • crt man
                  • Mar 2013
                  • 106
                  • England
                  Hi
                  Update A- board arrived yesterday, fitted no change.
                  ( went to work )
                  While I was there I thought about my problem,
                  I decided to put 8 blinks to the back of my mind,
                  I then thought about what I did to fix the original
                  problem,7 blinks and decided to lift the SC board and see
                  if the there was any arcing on the mountings.
                  Well there was and I set about cleaning the frame
                  and board, I put it back together and turned on
                  no change,
                  I then turned my attention to my handy work of
                  replacing transistors Q 401-3 and Q421-3
                  whilst inspecting them I noticed Q401 and 3
                  was loose on the board slightly so I re-soldered
                  them and tried again.
                  Success turned on and now have a working TV.
                  I now have a spare SS board and A board.
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    Good job! Mine also worked after 8 blink error , tv thought something was wrong due to the weight of the tv giving a lot of pressure on the bottom side of the tv. Probably bending the boards or something.....
                    • crt man
                      • Mar 2013
                      • 106
                      • England
                      Well
                      This thing just died again watched TV then turned off,
                      about an hour later turned on and found no picture.
                      Then went off with 7 blinks,opened it up and found
                      Q622 and 661 short,anything else I should check
                      or have I just been unlucky.
                      Alan.
                      • crt man
                        • Mar 2013
                        • 106
                        • England
                        Q622 and 661 replaced and working again,
                        threw me at first, as it went into standby
                        on switch on,strange as it was switched off
                        doing 7 blinks.
                        Alan.
                        • tw2005
                          • Oct 2011
                          • 6458
                          doing 7 blinks.
                          Alan.
                          yeah it's like a reset. will be interesting to see how it goes. how long has it been running for since last repair?
                          • crt man
                            • Mar 2013
                            • 106
                            • England
                            Done something like 60 hours give or take.
                            it was about 8 or 9 days.
                            Alan.
                            • Andre Gilbert
                              by Andre Gilbert
                              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                              11-20-2024, 08:52 PM
                            • AquaMan Ua
                              by AquaMan Ua
                              05-17-2025, 09:40 AM
                            • stecos
                              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                              by stecos
                              Hi everyone!
                              For my passion for technology I'm now collecting several...
                              11-28-2022, 11:39 AM
                            • aa10aa10
                              Panasonic Toughbook CF-33 mk1 BIOS repair
                              by aa10aa10
                              Good day,
                              I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                              I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                              01-21-2025, 06:13 AM
                            • Mnawar27
                              Panasonic CF-H2AU24EF3 bios locked
                              by Mnawar27
                              Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                              I need help to remove it,
                              thankyou all.
                              SN; 2FKCA26876...
                              11-16-2024, 08:00 AM
