Proscan PLED5529A Troubleshooting
  • dspiffy
    • Feb 2016
    • 19
    All the part numbers are the same as Haier LE55B1381
    I'll tell the whole story including stuff that might not be necessary!
    I bought this TV 2 years ago and it arrived damaged in shipment. There were some discolorations on the screen and the coaxial jack was ripped out. I filed a claim with FedEx and got to keep the TV. I figured it was still usable with these issues.
    A year later, it wouldnt power on. I opened it up and replaced the filter caps in the power supply, and from then on it worked fine.
    Interestingly, after opening it, recapping, and putting it back together again, all the discolorations on the screen went away.
    Also, I decided to rectify my biggest complaint with the unit and connected the speaker leads to a set of bookshelf speakers instead of the internal speakers. This improved the sound tremendously.
    Now, a year later, it wouldnt turn on again. This time rather than recap, I replaced the entire power supply board.
    It turns on but there is no longer any sound through the speakers. There is still sound through the headphone jack.
    Also, up until now I could still pick up some local digital channels with nothing connected to the broken coax jack. Now, nothing.
    I was going to order a replacement for the board the speakers plugged into-- I assumed it was an amplifier board-- but another thread on this forum says it's a TCON board.
    Also the coax jack appears to be part of the main board, I'm wondering if the best thing to do would be to replace that entire board? I dont NEED coax or even local channels but it is useful.
    I will post some pictures, they arent very good.
  • dspiffy
    • Feb 2016
    • 19
    Re: Proscan PLED5529A Troubleshooting
    Overview
    • dspiffy
      • Feb 2016
      • 19
      Replaced power supply
      • dspiffy
        • Feb 2016
        • 19
        Been trying to figure out what these blue leads go to
        • dspiffy
          • Feb 2016
          • 19
          The "amplifier board" and the adjacent board.
          • CapLeaker
            Leaking Member
            • 8061
            The TCON (Timing Control) board is only for the LCD. Has nothing to do with the sound or picking up channels. On your last picture the board in the bottom right corner is your main board. That's where the trouble lies and the board you need. The leads that disappear deliver the power to the backlights behind the LCD panel.
            Now if your symptoms are the result by replacing the power supply, we would have to do some diagnosing first, before throwing parts at it. Post a nice straight shot, high res. picture of the main board, so we can see something.
            • dspiffy
              • Feb 2016
              • 19
              How's this?
              • CapLeaker
                Leaking Member
                • 8061
                Try heating up the main board with a hair dryer and see what you get.
                  That is FRC (Frame Rate Coversion) PCBA.
                  • dspiffy
                    • Feb 2016
                    • 19
                    For reflow? I've heard of this being suggested, but I've never heard of it actually working.
                      For heating up the caps and may be cold solder joints, bad parts with heat sensitive, not for reflow.
                      • dspiffy
                        • Feb 2016
                        • 19
                        I can certainly give it a try. Surely someone I know has a hair dryer I can borrow.
                        • CapLeaker
                          Leaking Member
                          • 8061
                          that's where I was going with it.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Or if that fails, freeze spray the Spi flash Ic (normally U11 on them boards but not certain) sometimes the Ic corrupts meaning it wont load the firmware and makes the Tv stuck in standby. Freezing it allows it to read the files again and boot in alot of cases, if so you know your firmware has gone.
                            • dspiffy
                              • Feb 2016
                              • 19
                              The TV works fine except for the sound and coax input. It is not stuck in standby.
                              • dspiffy
                                • Feb 2016
                                • 19
                                Heated the main board with a hair dryer and reseated all the molex connectors. Now I have sound. The tuner does not work unless I stick a screwdriver where the broken coax jack was. Is there a way to replace only that part of the board, or is my only option to replace the entire main board?
                                • CapLeaker
                                  Leaking Member
                                  • 8061
                                  If you find the proper connector, no problem. Maybe check Digikey or Mouser etc.
                                  • dspiffy
                                    • Feb 2016
                                    • 19
                                    It's more than just the coax jack, it's broken off inside the shielded case. I assume I'd have to replace whatever is inside the shielded case.
                                    • CapLeaker
                                      Leaking Member
                                      • 8061
                                      pictures?
                                      • dspiffy
                                        • Feb 2016
                                        • 19
                                        Here's the best picture I can get.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • canadaboy25
                                          Panasonic TC-P54VT25 No image. A or D board?
                                          by canadaboy25
                                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                          01-17-2021, 01:06 AM
