Westinghouse LED TV 32 inch WD32FC2240
  • suiramix
    • Mar 2011
    • 131
    Hi there,
    This smart tv, Westinghouse 32" power up and stuck with "W" logo. The tv buttons and remote will not respond... for turning off it has to be unplug.
    So unplug it for 24 hrs. nothing same result.
    Google this type of defect just find out similar problem with Vizio and LG tvs...basically the EEPROM chip is corrupt or the main processor require reflow for a better connection with the mainboard. OK remove the back cover and tried to find out any bad components ...nothing ...everything looks fine... info from the main board, close to the processor there is "ST6308RTU-AP1" printed. This generic part number seems to be used in different tv as Element and Seiki... Regardless, Westinghouse website is useless for firmware upgrades or technical support. Any suggestions?
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Westinghouse LED TV 32 inch WD32FC2240
    Have you done a factory restart. Some of the Westinghouse firmware up grades do not work as they have moved them. The 26" Westinghouse I worked on I has able to get them to send me a email with the site that had the upgrade. It did not make a difference in the TV I work on, but it had another problem then yours. I would also check any place connectors are soldered as the solder may be there but not making contact.
    This is a from a different post of the firmware link. I do not know if this is the one you are looking for.
    This is the link for the upgrade to firmware of Westinghouse LD-2655VX the upgrade version is V.1 http://1drv.ms/1zXMDlI
    Instruction on how to upgrade the tv can be found on Westinghouse site under support for TV's LED up to 28"
    • suiramix
      • Mar 2011
      • 131
      Hi Keeney,
      Thanks for your reply...I tried to reset the tv by unplug the mains and while pressing power button plug it back...no change!
      I did check all the connector from mainboard...nothing loose!
      In order to do a firmare upgrade, the tv has to boot and pass the W logo screen, go to the meniu and select "upgrade firmware...
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Some TVs have a combination of buttons to push to reset the TV. You can also go out on BudM's site on TV repair as he may have come across this problem before.
        This site
        LCD TV and Monitor basic troubleshooting guides on bad caps. This is the link https://www.badcaps.net/forum/showthread.php?t=25810
        • jetadm123
          • 2169
          If you suspect the eeprom, try heating it up with a hairdryer to see if it makes any difference.
          • suiramix
            • Mar 2011
            • 131
            Hi Jetadm,
            Usually the EEPROM chip is 8 pin (small) IC, but I could not find any...so I guess the Toshiba TH58NVG2S3 (CMOS NAND EEPROM) TSOP-48 is the one I have to reflow (see attached photo). Thanks!
            • garfield-cat
              • May 2014
              • 12
              If anyone figures out how to fix this please share .. I am having the same issue
              • atranquilo
                • Aug 2017
                • 3
                • canada
                Helo, i have the same problem, TV model Westinghouse WD32HW2490, the board is the same, ST6308RTU-AP1, so the problem is in the eeprom, i read that is possible to erase it by shortcircuit two pins, my question is, were is the eeprom memory located in this board?
                • gn2
                  • Dec 2013
                  • 5
                  Just got a tv with this same problem, it must be a common fix, if anyone has fixed this, please post...
                  • tsitsos
                    43 inch tv firmware issue.The board is cv338h-t42
                    by tsitsos
                    Hello all. I would like some help on installing a firmware on tv..
                    4 days ago i changed a channel and the image became complete blue and the tv unresponsive. No matter what i did ( like unplugging the power , press the power button for minutes etc etc nothing helped) Then i had an idea to flash it via usb. The brand is very uncommon (smarttech) so i had hard time finding the right firmware. i ended downloading 2 just in case. I flashed the first one with usb and pressing the power button like 5 times. The installation was successful and tv worked ok with some little problems that right...
                    03-11-2022, 07:32 PM
                    HP ZBook Firefly 16 inch G10 Notebook Specification for Upgrade or Repair
                    This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-07-2024, 07:20 AM
                    09-07-2024, 07:19 AM
