panasonic led 32- no standby power no led?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: panasonic led 32- no standby power no led?
    Standby gen supply faulty on PSU board
    Could well be the controller chip, Pan had issues with some Plasma sets doing much the same, no stdby supply....
    TELEFIX
    • Diah
      • Feb 2013
      • 6496
      Originally posted by simon.ribeiro
      no standby voltage with motherboard unhooked
      measured ar terminal 8 of P2
      what are you talking... take out the psu out and look on the back of it
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Originally posted by Diah
        lol every one had his thought, but one thought we will not disagree, when you design boards and the big names companies buil it with cheap bad quality parts. who are in charge the designer or the builder
        Thats true, but Ves design them to a cost but not very well at all. I would not hate Vestel boards that bad if they at least made sure the diodes that they parallel on the Psu are rated to the proper reverse voltage that they expose them to on start up, but they dont which causes alot of issues.
        • Diah
          • Feb 2013
          • 6496
          agree with you, but Vs. had nothings to do with PSU and LED ROW or side. the brands name design this and give it under other hit names like LED PLUS or edge.
          • simon.ribeiro
            • Apr 2015
            • 13
            • portugal
            i have removed the board and there is nothing obvious
            • simon.ribeiro
              • Apr 2015
              • 13
              • portugal
              #26
              where can i buy a new board?
              • tw2005
                • Oct 2011
                • 6458
                The diagram shows pin 8 as TV_SUB_ON at P2.
                STBY6V should be pins 1&2
                Looks like IC7601 generates 5.8V
                There's a fusible link PA7601, will be a tiny SMD link, worth checking that or see if 16V is reaching Pin 12.
                • CapLeaker
                  Leaking Member
                  • 8340
                  So if you have 350V on sounds like the power factor correction circuit isn't working on the power supply. So question still remains if the 5.5V STBY is there or not. At this point I am not sure if you measured that correctly or not.
                  Find C7301 or C7300 and measure DCV directly at those capacitors. positive on positive of the cap and negative on the negative side.
                  Next:
                  Go to P2 connector and measure test points TP7501 to TP7511. Negative on pin 15 or 16 and probe all test points I mentioned.
                  Post all your voltages measured with the pin out names.
                  • tw2005
                    • Oct 2011
                    • 6458
                    marked the IC and fusible link
                    • simon.ribeiro
                      • Apr 2015
                      • 13
                      • portugal
                      #30
                      ok so,
                      C7301 Reads 345v dc, c7300 is not fitted to this board.
                      tp7501-0v
                      tp7502-0v
                      tp7503-0v
                      tp7504-0v
                      tp7505-0v
                      tp7506- -5.5v
                      tp7507-0v
                      tp7508-0.3v
                      tp7509-0v
                      tp7510-0v
                      tp7511-0.5v
                      • simon.ribeiro
                        • Apr 2015
                        • 13
                        • portugal
                        #31
                        at terminal 2 D7502 I have 12.5 v
                        at terminal 2 D7501 I have 34.6 v
                        • simon.ribeiro
                          • Apr 2015
                          • 13
                          • portugal
                          #32
                          I have 0 volts terminmals 1+2
                          PA7601 is good
                          I have 12 v at pin12
                          • CapLeaker
                            Leaking Member
                            • 8340
                            ok so,
                            tp7501-0v
                            tp7502-0v
                            tp7503-0v
                            tp7504-0v
                            tp7505-0v
                            tp7506- -5.5v
                            tp7507-0v
                            tp7508-0.3v
                            tp7509-0v
                            tp7510-0v
                            tp7511-0.5v
                            The PFC circuit is off, you just get rectified mains. = The power supply is off. There are no voltages on that main board in order for it to turn the PSU on.
                            I don't understand why you measured 5.5V only on TP 7506, as it should be the same on TP7505 and TP7504.
                            What are all the voltages measured on the pins of IC7601?
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                              by sam_sam_sam
                              07-01-2024, 06:34 AM
                              by sam_sam_sam
                              After all of...
                              07-13-2024, 08:14 PM
                            • JimBanville
                              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                              by JimBanville
                              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                              09-13-2023, 07:21 AM
