Build an Ultra-Reliable TV!
  • ZnsaneRyder
    • Oct 2015
    • 88
    • Merica
    For you TV gurus, which TV would be a good platform for upgrading parts to make an ultra-reliable TV that will run for 10-20 years, and does not require hard to get or obsolete parts years later.
    1. Which TV does NOT regularly kill mainboards, Tcon, or other Digital boards
    2. Which TV was built WELL, but only has failures with bad caps that are known to fail that can be upgraded to superior ones?
    3. Which TV always fails MOSFETS, DIODES, or CAPACITORS on the PSU, but never fails any of the other boards, just the power supply? That would be the PERFECT candidate for upgrading with Over-Spec parts that will outlast the intended lifetime.
    Which TV would be the one you would recommend?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Build an Ultra-Reliable TV!
    Look at something CRT based, everything built since then is too digital built after 2006 and therefore lead-free and crap.
    TELEFIX
      • 31294
      forgetting the lead-attack, yes - something CRT based.
      and preferably NOT one of the widescreen tubes with a narrow neck - the guns short-out on those after a few years!
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Crt based with fans too cool the Pcb, and everything has re-in forced solder pads with extra solder.
        • ZnsaneRyder
          • Oct 2015
          • 88
          • Merica
          OK, I have to agree, CRT for the win. (I only use flat-screen CRT for all my computers).
          What about LCD ? I was thinking of modding an LCD to make it better. I am already doing an LED project to upgrade the LED LCD TV to better LED that won't burn out.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Lcd is junk all around avoid lucky if Lcd lasts 10 years ! Plasma maybe, if you get something like a Pioneer Kuro and add some fans to help it cool even though they dont get hot best to just give it that little boost. Also Dlp are stupid the lamp fails after a few thousand hours of use as well as the dlp Ic and the image quality is just crap.
              Why CRT? Shit picture quality, horrible 15kHz whine (for those of us with good hearing), flicker, picture size varying with brightness, mediocre focus...whatever. I know there's an automatic love on this forum of anything old, the idea that the old times were better, but let's be honest, no one wants a 300 lb Sony 36" CRT that sucks 300W more-or-less continuously when you can have a 42" Panasonic plasma that weighs only 100 lb and consumes half the average power and gives you a full HD image.
              Sure some CRTs last ages. But many died early on, too. CRT technology is only reliable because it has been refined over 70+ years.
              There is nothing wrong with a well designed plasma display or even LCD display - they can be sufficiently reliable and I would say better than 99% of CRTs that were produced.
              Boeing and Airbus use LCDs for flight computers... NASA replaced flight computer displays with LCDs in shuttle upgrades... And military equipment often uses old plasma monitors too.
              DLP with LED bulb looks pretty nice but I still prefer a plasma or OLED display.
              Still my brother has a Full HD 3D projector that cost £2k new, it's still running on the original bulb, although he only uses it for the odd movie. If you're that kind of person a projector works fine.
              And there's nothing junk about LCD when designed right.
                • 31294
                you must have had some really shit tv's - sounds like Orion sets.
                good tv's are silent (no loose coils or yoke windings),
                dont flicker because they arent using monitor tubes with short persistance phosphor,
                and the brightness control does not effect the power to the scancoils.
                as for the focus - adjust it of fix the damned HT first!
                the problem with being too young or only working in a workshop - you only see stuff that's broken or shit.
                  • 31294
                  that's different, flight crt's have to be magnetically shielded and it's expensive.
                  if you re-orientate a crt while it's on you can have gausing problems and throw the focus out because of the earth's magnetic poles effecting the tube.
                  when i worked in amusement machines we knew this problem well,
                  move a machine to face a different direction and you have to re-power it to get it to de-gaus the tube.
                    I'm talking about CRT TVs. CRT monitors are less bad because the design is usually better and the scan frequency is higher. Still, they are heavy, suck a ton of power and take up unnecessary desk space. How much space do I save with dual 24" LCDs vs two 24" CRT behemoths? I couldn't have the same productivity that I do with LCDs.
                    Most CRT TVs share a common horizontal scan and flyback signal. So, if the tube draws more current (due to higher brightness) the picture size in the horizontal axis will change. Don't believe me? Look at any CRT television as the picture varies...the picture size will also change! Also, often, the B+ is regulated off the flyback, and the B+ controls the vertical scan, so that may well change too. Sony HD CRTs and most monitors used separate scan and flyback circuits, but that was always an added expense and never a standard feature.
                    Focus goes beyond the focus voltage. The colours are often slightly misaligned creating fringing, even on the best Sony CRTs. This is most noticeable on CRT TVs though. LCD or plasma doesn't have this.
                    And weight? The total weight of my monitor set up is less than 40kg and can be mounted on a simple clamp bracket. I'd need to reinforce the floor to put in two 24" CRTs.
                    Flicker: my LCDs don't flicker at all (I've checked with a high speed camera), but CRT monitors flicker at 60Hz **regardless of phosphor persistence!** That's not too bad for a TV (plasma do the same, 600Hz but with 120Hz component) but it's completely unacceptable for a monitor which I'm in front of 8+ hours a work day.
                      Magnetic shielding is part of the problem but the other saving is in power consumption and power dissipation. This is especially critical in the case of the space shuttle where power is limited by an 8kW fuel cell and power dissipation is very difficult (vacuum of space means you can only radiate heat via blackbody losses.) It's also surprisingly important in modern aircraft as the density of electronic systems increases and cooling becomes more difficult.
                        • 31294
                        i'v never seen a tv with B+ regulated from the flyback, it's always come from a switchnig psu or a linear dropper fed from an optocoupler.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Orion Tv's are very well built IMO I have a 32" and wow every cap is Rubycon ! And its been working for over 10 years still working today, not had to repair it.
                          • RCA2000
                            • Sep 2014
                            • 111
                            My take...A CRT set...with a CRT built like either the Zenith Chromacolor tubes or the Hitachi made tubes form the late--80'S--early 00's.. RCA uses a LOT of them...they just last and last... maybe even a MILITARY grade tube--with exrra heavy cathodes...
                            Chassis--bulit like a CTC 40-44 or Zenith flat chassis set. VRT power supply--SS hv rect and a SEPARATE post HV_reg--like a projo set or monitor uses. A PAIR or Horiz. out transistors on a BIG sink. Discrete Vert--out and video outs-- Discrete TUBE audio outs--maybe 7868- P-P or so.
                            120C caps. THROUGHOUT.
                            I t WOULD be HEAVY...but would last a GENERATION..
                              Depends on the design. A lot of TVs switched away from using the main flyback as the primary SMPS converter as it is pretty lossy (high voltage design) however quite often in older CRTs it generated the B+ and other supplies (audio etc.)
                              The problem with the horizontal scan remains regardless. Picture size WILL change. And this is not a good thing if you enjoy watching a good quality image.
                                • 31294
                                best CRT device ever = Electrohome G07
                                they just go on forever - even the caps last 20years before showing a problem!
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  Come on, You Must remember Thorn Syclops, as from what you've said in past, I reckon you are similar age to me.....
                                  --Bloody horrible things though, but SMPS was based round line o/p stage....
                                  TELEFIX
                                    • 31294
                                    i remember some pye bastard-chassis that was rectified live with thumb-wheel pots on a vertical panel that almost always got you!
                                    it was a tv, but it was often used without a tuner as an industrial open-frame monitor chassis!
                                    and i remember philips KT3 modular chassis with a tripler too.
                                    luckily i avoided thorn gear.
                                    • michael dranfield
                                      • Jan 2016
                                      • 232
                                      • England
                                      And as far as I am aware military and medical applications are exempt from using lead free solder.
                                      • michael dranfield
                                        • Jan 2016
                                        • 232
                                        • England
                                        I have a brand new, still in its box re gunned thorn new life tube for the Thorn 9000 chassis, also still have parts in stock to repair all the early thorn sets, right down to the 1400 chassis !
                                        • dmill89
                                          Emachines T3104 "Sleeper"/random parts build.
                                          by dmill89
                                          I decided to see what kind of "sleeper" build I could do on the Emachines T3104 from cheep/free thread with the "random junk" I had laying around (with the exception of a SATA to IDE adaptor I bought to make the original Emachines optical drive to work).
                                          Before:
                                          Specs:
                                          Motherboard: FIC K8M-800M
                                          CPU: AMD Sempron 3100+
                                          RAM: 512MB DDR-400 (2x256MB)
                                          GPU: Integrated VIA Unichrome Pro
                                          PSU: HiPro HP-P3527F3 300W
                                          HDD: None/removed (case sticker indicates it originally had a 100GB IDE HDD)
                                          ODD: Lite-On DVD-ROM/CD-RW...
                                          01-23-2023, 09:06 PM
                                        • tofuSCHNITZEL
                                          Fujitsu Lifebook E547 vPro
                                          by tofuSCHNITZEL
                                          I have a Fujitsu Lifebook E547 vPro that does not boot anymore after Windows Update tried to install a new Bios version. Screen stays black no post - only the numblock light blinks.
                                          What I've tried:
                                          I have used my CH341A to read the bios chip (25Q128FVSQ) (Dump attached) - I think the dump is "good" because I could find the Serial number in the data and also the Winkeyfinder found a windows key.
                                          for the lack of any other Idea I took the bios from this post (https://www.badcaps.net/forum/troubl.../troubleshooti...
                                          10-15-2025, 04:26 PM
                                        • Mark D
                                          Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                                          by Mark D
                                          The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                                          10-29-2024, 03:15 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • 2elw
                                          SVOD4 PCB pictures + parts
                                          by 2elw
                                          Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                                          STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                                          GW1N-UV9UG169C6/I5 FPGA - Its a...
                                          07-04-2025, 12:23 PM
